Originally Posted by
justbabak
ok, I checked it, sounds good, but there is one question, the encoder is absolute or relative? It is important because my problem with the current drive is that it makes a small dislocating movement upon power-on! so after a power failure or after each start-up of the machine, all the axes make a small move (between 0-0.2mm) unexpectedly so I have to adjust all the coordinates again.
so I have to makes sure that the new drive system which I want to move on will solve this problem. does it solve it?
