588,617 active members*
4,169 visitors online*
    Jan 2008
    8
    Question bridgeport II r2e3
    how do i replace the y screw, or get to it to check it out.
    i have .005" backlash?????????????????????
    thanks
    whaley
    Jul 2005
    409
    Y screw on R2E3
    Whaley,
    In order to get to the y screw, If you raise the knee all the way up you can look at it from underneath. Look to see if the screw is clean and has oil. You can remove the front black cover to get to the front end of the screw. If you remove the belt guard from the Y motor you can check the belt tension. If you raise or remove the rear rubber way cover you will see there is a sliding metal cover with 2 screws. Remove the 2 screws and lift up the cover and you will see the screw/ pulley, and the bearings.
    There is electronic backlash compensation in the Boss8 that can be set.
    How did you check the .005" backlash? Is it worse on the ends of travel vs. in the middle of the y travel?
    I have a seriesII R2e3 that needs the ways scraped & if th egibs are too tigh, the backlash is high on the ends but less in the middle.
    Hope that helps,
    Cutmore
    Jun 2003
    866
    Is this a series II with box ways?
    Jan 2008
    8
    this mill is a series II, with boxed ways
    i checked the lash by cutting a rectangle .5 wide by 2" long along x, with y only changing
    direction 1 time.
    i installed a new ajax , centroid controler & thy say the control cant handle .005"
    backlash? when i install backlash comp in control i cant see any differance????????
    thanks
    whaley
  1. bridgeport II/r2e3 boss 8
    By whaley in forum Mechanical Calculations/Engineering Design
    Last Post: 01-02-2008, 06:02 AM
  2. Bridgeport R2E3 Need Help Got Problems
    By paparandy in forum Bridgeport / Hardinge Mills
    Last Post: 05-19-2007, 05:13 AM
  3. Need Display Bridgeport R2E3 with Boss 8
    By hrhoward in forum Bridgeport / Hardinge Mills
    Last Post: 11-26-2006, 11:31 PM
  4. Bridgeport R2E3 with Boss 8
    By John Bennett in forum Bridgeport / Hardinge Mills
    Last Post: 09-17-2005, 01:35 AM
  5. Bridgeport R2E3 with Boss 8
    Last Post: 04-06-2005, 04:06 PM
