603,362 active members*
3,493 visitors online*
IndustryArena Forum > Tools / Tooling Technology > Calibration / Measurement > measuring a diameter by x & y point values
    Jun 2007
    7
    I'm trying to write a probe routine that will check a diameter. I don't have a problem, getting the x & y values. I don't know the mathmatical formula to get the diameter. The routine will measure 4 or more equally spaced points on the diameter, up to say 30 points. I want to be able to calculate the average diameter, and the maximum and minimum diameter. Any suggestions?
    Jul 2003
    1220
    This will give you the centre XY and diameter from any three points.
    X1 = ?:X2 =?:X3 = ?:Y1 =?:Y2 = ?:Y3 = ?
    Ma = (Y2 - Y1) / (X2 - X1)
    Mb = (Y3 - Y2) / (X3 - X2)
    X = ((Ma * Mb) * (Y1 - Y3) + (Mb * (X1 + X2)) - (Ma * (X2 + X3))) / (2 * (Mb - Ma))
    Y = -(1 / Ma) * (X - (X1 + X2) / 2) + (Y1 + Y2) / 2
    Diameter = (Sqr((X2 - X) ^ 2 + (Y2 - Y) ^ 2))*2
  1. Shaft Diameter, LeadScrew Diameter, Motor Torque?
    By cnc-newb in forum DIY CNC Router Table Machines
    Last Post: 12-24-2007, 09:51 PM
  2. Shaft Diameter, LeadScrew Diameter, Motor Torque?
    By cnc-newb in forum Uncategorised MetalWorking Machines
    Last Post: 12-15-2007, 04:25 AM
  3. Busellato Optima Point To point
    By Malacara in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 12-12-2007, 01:22 AM
  4. converting point to point programs
    By kevinwd1 in forum Uncategorised CAM Discussion
    Last Post: 06-11-2007, 05:45 PM
  5. Point to point programs
    By Frankbals in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 05-22-2007, 09:12 PM
