587,035 active members*
2,824 visitors online*
    Nov 2007
    79
    fanuc 15 m spindle trouble
    hi every one , i have a trouble with spindle speed value.
    i put M3 S800 EOB when I push start , the spindle start rotating in a very high speed(max speed is set to 3500 RPM ) .
    since i dont have a parameter sheet then
    i need to make sure that the parameters values which are responsible for the spindle are correct
    these parameters as follows:
    #5615 value = 15
    #5616 0
    #5617 10
    #5618 1
    #5619 4050
    #5620 10
    #5621 864
    #5622 3895
    #5641 800
    #5642 3500
    so please if any one can tell me if theses values are correct or not , and if it's not correct , i need the correct values
    thanks a lot
    Feb 2007
    464
    I don't know the exact values but this tells you what they are for.
    Code:
    5615 Spindle motor speed during the spindle gear shift
    Parameter input (Not used in the Series 15–TT)
    Data type : Word
    Valid range : 0 to 4095
    Specify the spindle motor speed during the spindle gear shift.
    This parameter is valid for the FS3 or FS6 interface.
    Time from when a spindle gear select single is issued
    5616 until when the new spindle speed is output
    Data type : Word
    Unit of data : msec
    Valid range : 0 to 32767
    When the type of spindle speed analog output or spindle speed binary output is A (TPB in parameter No. 5601
    is set to 0), specify the time from when a spindle gear select signal is output until when the new spindle speed
    corresponding to the specified gear is output.
    This parameter is valid when the FS3/FS6 interface is used.
    5617 Spindle speed during the spindle orientation
    Data type : Word
    Unit of data : rpm
    Specify the spindle speed during the spindle orientation.
    5618 Minimum clamp speed of the spindle motor
    Data type : Word
    Specify the minimum clamp speed of the spindle motor.
    Setting = (minimum clamp speed of the spindle motor/spindle motor speed corresponding to the
    maximum output) x 4095
    5619 Maximum clamp speed of the spindle motor
    Data type : Word
    Specify the maximum clamp speed of the spindle motor.
    Setting = (maximum clamp speed of the spindle motor/spindle motor speed corresponding to the
    5620 Time until the speed arrival signal is checked
    Data type : Word
    Unit of data : msec
    Specify the time from when the S function is executed until when the speed arrival signal is checked.
    Checks whether the speed arrival signal is on at the beginning of the cutting feed (G01, G02, G03, etc.) block.
    If it is off, the system waits until it is turned on, then begins the pulse distribution.
    When the cutting feed is specified in the same block as the S function, waits for the specified length of time after
    the S code is sent, then checks the speed arrival signal. (See the diagram above.)
    5621 Maximum spindle speed corresponding to gear 1
    5622 Maximum spindle speed corresponding to gear 2
    5641
    Minimum spindle speed of gear 1 under the constant
     surface speed control
    5642
    Minimum spindle speed of gear 2 under the constant
    Stefan Vendin
  1. fanuc 6t trouble
    By ezjn in forum CNC Machining Centers
    Last Post: 11-15-2007, 03:52 AM
  2. trouble with spindle in tnc 151
    By PRIOR666 in forum Bridgeport / Hardinge Mills
    Last Post: 01-20-2007, 07:59 PM
  3. fanuc 10m spindle trouble
    By ezjn in forum Fanuc
    Last Post: 09-04-2006, 11:15 PM
  4. fanuc 10m trouble
    Last Post: 09-04-2006, 06:41 PM
  5. Gerber Router Spindle trouble
    By Smackre in forum Gerber
    Last Post: 07-24-2006, 02:31 AM
