588,556 active members*
4,524 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Plotter Parts Survos Belts Screws Etc...
    Apr 2006
    4
    Post Plotter Parts Survos Belts Screws Etc...
    Has anyone used parts from a plotter to make a CNC router? I have an old Large Pen plotter and was wondering if I could use the survos and control boards or drivers from the plotter to drive the Survos on the CNC router?
    May 2007
    380
    I just finished tearing an old E size (24x36 inch) pen plotter. The motors look too small. I don't see how the driver board could be used with G code. The pulleys look good, but the belts are old. Then there is only parts for 2 axis.
    John
    Jun 2007
    3735
    Cool Use for a plotter.
    I am retrofitting an A2 Roland Plotter to be a pick and place SMD component machine complete with multi pickup tools and multiple parts carriers.
    Most plotters are much to light and under powered to be used as a router.
    I have to be careful that the parts attached to the carriage are VERY LIGHT,
    and I am only placing parts that weigh milligrams. Inertia rules cos I want speed.
    Hope to place 20 - 30 parts per minute. Better to be ambitious?
    Aug 2004
    3215
    Quote Originally Posted by johnmac View Post
    John
    24"x36" is D size paper.
    Jun 2007
    3735
    Talking Still using the plotter electronics. No need for G-Code.
    The plotter doesn't know the difference between a pen and a suction tube.
    Just move to a position, pen down, release vacuum, pen up and go suck up another part. Component orientation and alignment mechanism at pickup station.
    If it writes with solder paste instead of ink it won't be none the wiser either.
    If one of the pens is a TV camera so be it.
    Making full use of original DMPL/HPGL language through 1 serial port.
    That leaves a parallel prot to manupulate the parts feeders etc.
    Custom software in VB.
    Only thing missing is the hot air gun 'PEN'. It might melt some of the plastic!
  1. Need Digitizing for 4 parts and accompanying screws and pins
    By theclive in forum Employment Opportunity
    Last Post: 05-10-2007, 08:42 PM
  2. Replies: 13
    Last Post: 03-01-2007, 12:28 AM
  3. Belts to replace long ball screws? What are your thoughts??
    By runinbymdnt in forum Linear and Rotary Motion
    Last Post: 02-17-2007, 11:31 PM
  4. Replies: 44
    Last Post: 12-31-2004, 01:54 PM
  5. FAQ's (Motion Transmission,Acme, Ball, Allthread Screws, Cogs, Belts, bearing, etc )
    By chuckknigh in forum FAQ of DIY CNC Machine Building
    Last Post: 04-29-2004, 02:55 AM
