588,529 active members*
7,261 visitors online*
Results 1 to 6 of 6
    Dec 2007
    57
    M12VC Adapters
    Hello,
    I'm wondering if there is a / how to make a Drill head adapter for this.
    Find a drill head shove it on a bar and shove it into the router?
    The reason I'm asking is because all my drill bits are different sizes
    DL
    Sep 2007
    740
    I haven't seen anything. Many use the router and bit to "spot" holes and then drill with hand drill or drill press. The router motor turns too fast to drill most materials with a drill bit.
    Dec 2007
    57
    Ahh I see. Well if anyone sees anything or is doing anything let me know
    Oct 2004
    727
    ramasule,
    How about making a detachable mount for your CNC table. You can then make an additional mount/holder for an electric hand held drill and swap them as necessary for your routing and drilling operations.
    Just a thought,
    HayTay
    Don't be the one that stands in the way of your success!
    Dec 2007
    57
    Im already in the process of doing something like that. The problem is I am building a offset of limit switches to detect drill bit home. This is so the drill bit is always referenced as machine to eliminate the mounting offsets.
    Was just looking for a quick thing to slap into the router. I think ill go get a drill head chuck or a couple differnt sizes. Get the right steel shafts and turn the other end to fit in the router. That should work.
    Oct 2004
    727
    How about taking an old hand drill, or one from a yard sale or flea market, and strip the chuck and drive shaft from it. Of course, you'll have to cut the shaft down to a manageable length for your router. The shaft diameter may also need to be turned down to fit a standard size router collet. I had taken apart an old Sears Craftsman drill circa the '60's or '70's and if I remember correctly it used an imperial sized 1/2" shaft (and bearings!) that should fit in a 1/2" router collet nicely.
    That should enable you to quickly burn up a bunch of drill bits. (flame2)
    HayTay
  1. Hitachi Router M12VC Collets
    By RJSheets in forum Open Source CNC Machine Designs
    Last Post: 04-27-2009, 03:15 AM
  2. USB to Parallel adapters?
    By Chris64 in forum Gecko Drives
    Last Post: 12-28-2007, 06:40 AM
  3. Bought a Hitachi M12VC!!
    By randyf1965 in forum DIY CNC Router Table Machines
    Last Post: 09-30-2007, 02:50 AM
  4. Hitachi M12VC Dimensions
    By Bowman in forum DIY CNC Router Table Machines
    Last Post: 05-23-2006, 05:42 PM
  5. Another Source for Collet Bushing Adapters
    By HayTay in forum DIY CNC Router Table Machines
    Last Post: 03-31-2006, 10:53 PM
