603,836 active members*
2,900 visitors online*
    Apr 2004
    439
    spring washer question
    Jun 2004
    201
    I know the nut is used succesfully by some people, but I was shown an easier way to (load) the nut.
    Make a block that is threaded for the size of the ball nut and put a ball nut on either side. Us the ball nut it self as the spring by putting your ball screw through the 2 ball nuts and simply unscrewing one ball nut until there is zero lash.
    This image was sent to me by Camtronics. I think this is from his own personal mill.
    Apr 2004
    439
    Thanks replicapro that looks good was thinking about doing it that way too
  1. Tapered roller bearings preload question
    By sendkeys in forum Uncategorised MetalWorking Machines
    Last Post: 03-14-2006, 09:13 PM
  2. Extremely basic machining question.
    By touser in forum MetalWork Discussion
    Last Post: 06-19-2005, 06:51 AM
  3. Hobbycnc controler question
    By chas in forum Hobbycnc (Products)
    Last Post: 09-09-2004, 11:00 PM
  4. Just a question about plunge milling.
    By Machine1 in forum Hard / High Speed Machining
    Last Post: 01-29-2004, 03:36 AM
  5. HF lathe question
    By rs1300 in forum Uncategorised MetalWorking Machines
    Last Post: 01-19-2004, 06:22 PM
