586,121 active members*
3,330 visitors online*
    Feb 2007
    35
    Question No Interrupt on vf2 2000
    Hi Lads..
    Have a new one. My vf2 just stopped in mid program "No Interrupt" no alarm and screen frozen. Any Ideas
    Regards
    Pat
    Jul 2005
    12177
    I have not had this on a machine but years ago I had this kind of message on some computer controlled equipment I was building. It meant there was something major wrong down in the firmware somewhere. Sorry to be pessimistic but I think the minimum you need is a visit from a Haas tech with a disc containing a software reload with the maximum being a new processor board.
    Sep 2006
    48
    A "No Interrupt" alarm means that the Mocon and the CPU are not talking. Check the power supply connection in the the lower right corner of the Motion Control PCB (Located in the upper left inside the control under the sheet metal cover).
    The red wire should have 5VDC. If this 5 volts drops out you will usually get motor overheats as well (thermal switches run off of 5vdc too).
    Could be a loose connection or a low voltage power supply going bad.
    Loose Nut
    Apr 2007
    178
    if you power on the machine do you see x y z overheats in the alarm history if so you need a new lvps the computer style power supply haas sells a new solid state one now $300.00 but you can source the old one and modify the power cable i think it is an at power supply 200w
    REYTECH Machine Service Corp. CNC repair NY, NJ
    http://www.reytechmachine.com
  1. E-stop, Interrupt The 110v Ac Or 28v Dc?
    By Mr.Chips in forum CNC Machine Related Electronics
    Last Post: 02-06-2007, 03:49 PM
  2. 2000 RPM new TL-1
    By xyzcnc in forum Haas Mills
    Last Post: 04-19-2006, 04:10 PM
  3. inputio interrupt driven?
    By howling60 in forum CamSoft Products
    Last Post: 02-10-2006, 08:38 PM
  4. Optical Switch w/Interrupt mechanism
    By cnczane in forum DIY CNC Router Table Machines
    Last Post: 11-10-2004, 03:51 PM
