588,058 active members*
5,347 visitors online*
    Jul 2005
    969
    table tilting problem
    ok i have a slight problem, two days ago i got a longer table for my "bf-20" mill and i have a slight problem with the adjustment i have some tilting i would say about 0.003" to 0.004" on a distance of 6" i did play with the gibs but even with them tighten all the way i get those reading, i can easly see oil been pushed out when i push up and down on the table in between the table and the y saddle the only way i can minimize it more is by tightning the two lock screw in the front but this is not an option since it locks down the table any idea would be appreciated
    The opinions expressed in this post are my own. -Les opinions exprimé dans ce messages sont les mienne
    Jul 2005
    969
    ok never mind i found the problem the gibs and the dovetail of the new table do not match... well not that it does not match but the with of the dovetail of the new table is slightly smaller so ounce the screw was screwed all the way the gibs still had some play so well i found a temporary fix by adding some masking tape to the back of the gibs wich made it a bit thicker by 0.005 but it could still be a bit thicker cuz i still get about 0.0015 of play when i push up and down so ill try to see if i can find a 8"x0.5"x0.006 strip of shim since a shim wont also have the squishiness of the masking tape
  1. My cnc table
    By scrambled in forum Plasma, EDM / Other similar machine Project Log
    Last Post: 07-24-2010, 02:11 PM
  2. machine problem or software problem?
    By bcnc in forum Syil Products
    Last Post: 10-26-2009, 03:51 PM
  3. Left tilting or Right Tilting Table Saw Blade?
    By diarmaid in forum Metalworking- / Woodworking Tooling / Manual Machining
    Last Post: 02-27-2009, 03:57 PM
  4. XY table design basics, linear ways to table size ratio?
    By Konstantin in forum Mechanical Calculations/Engineering Design
    Last Post: 03-13-2007, 06:21 PM
  5. Heidenhain TNC 426 - rotary table problem
    By nbjs in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 12-05-2006, 04:52 PM
