603,804 active members*
3,055 visitors online*
IndustryArena Forum > Hobby Projects > Hobby Discussion > RC copter camera platform, scratch built
Page 1 of 2 12
Results 1 to 20 of 24
    Jun 2004
    34
    I am not positive this is the proper place for this topic, if not, CNCadmin, please move. (tia) I am in the very early design phase for a “heavy lift” RC chopper to use as a stable camera platform. There is a lot on the net about aerial photography, ranging from weather balloons to kites to model rockets. But all are lacking the stability I desire. This would strictly be hobby related, but one of my other interests is Simi-pro photography. Anyway, to the idea. It has been done before, for very low-end toys, but I want a twin-rotor craft, using counter-rotating rotor blade assemblies. Fixed pitch for simplicity and reliability. Both rotors would share a common axis, about the centerline of the craft. No tail rotor would be employed, but maybe two thrusters on pods extending from the main chassis that could be controlled independently. Forward and reverse thrust could spin the craft, or used in tandem made the craft to propel itself fore and back. Again, the concept has been used to steer RC blimps, and the lift system has been used to power cheep play toy copters. But I wish to use it with a hanging payload of high-end photographic equipment. I wish to use commercial, replacement rotor blades. How would we calculate the lift, stall and desired RPM at certain prealligned pitches? What would be the power requirement to turn a pair of 600 mm blades at say a 22 1/5 degree fixed pitch, and what size payload could I expect to lift? Oh, and another little requirement for this little toy, no fuel to damage the precious payload, we need to use an electric motor. If I cannot rely on a model motor to do this job, any suggestions for an alternative. Maybe the motor from an 18-volt Dewalt drill? Would most likely get too hot in near continuous use. At this early point in the concept, any ideas could be entertained.
    Smile, life is too short to sweat the small stuff.
    John M. Stuedle
    The Shop Out Back Aviary
    6855
    For electric power a dewalt would not be a good choose, but a hacker twin geared properly would be.
    Fixed pitch main blades will not provide the need stability your looking for. It really would need to be collective, as for blades their are may types of blades one in particulate is a blade designed for high lift.
    Jun 2004
    34
    If I have the payload in a hanging “platform”, using it to help stabilize the craft like the tail of a kite, would I not be able to use fixed pitch blades? This is the concept used with many small (18 ft.) blimps and round weather balloons with payloads. But they typically lift 14 – 16 oz. I am looking for 4 to 7 lbs. of gear dangling about 36” below the airframe. (PS, after mentioning the dewalt, I realized the error in the thought.)
    John M. Stuedle
    6855
    The problem with fix pitch is that it can't react to cyclic and collective pitch change quickly, there is a delay. That is on reason that collective can be made to be allot more stable. A danging object on helicopter platform will do little to provide stability in fact to opposite may be true.
    Jun 2004
    34
    Would you build it with collective on both rotors, or just the upper rotor? I would think if both were setup, not only would it be a design nightmare, but a programming hassle.
    John M. Stuedle
    6855
    You would have a bell-hiller mix type head in that you would have the rotor collective and a fly-bar system for stability.
    cherck this site out- http://www.bergenrc.com/Observer.asp
    Jun 2003
    167
    Just a thought, Do you know how to fly a model helicopter? I fly R/C airplanes and have been around the helicopters and watched several people learn (or try) to fly them. They are not for the faint of heart. They can also take some people a very long time to fly well and even longer to fly with enough confidence to hang several thousand dollars worth of gear off of. I would recommend you find a local R/C club and get to know several helicopter flyers and get familier with the equipment before starting to try and build one. Most flyers are happy to show off their models and give you information. They can be VERY expensive to repair or build. Just my .02 worth. Good luck it's a cool idea. Ron
    Jun 2004
    34
    Let me answer by saying that anything worth doing is worth doing well. If this gets built, it will be made to work and I will invest the time and talent to make it work right. I know I have technical problems to overcome. What I had in mind was a craft that would accelerate and climb vertically based on rotor RPM alone. Both rotors would turn in opposite directions at exactly the same speed on the same axis/centerline, locked by gearing and driven by the same motor eliminating the need for a tail rotor. If the craft needed to be tethered, so be it, and for safety reasons, that might be acceptable. My planned use was to be able to go on location, climb vertically 200 to 400 feet, get the shots and recover the craft. If what we are saying, is that stability after the technical obstacles are overcome will be an issue, any other ideas? As mentioned, weather balloons are a pain, a large balloon capable of lifting my payload would require several hundred cubic feet of helium each flight. Cost per flight would be in the hundreds of dollars and prep time per flight prohibitive. Fixed wing aircraft are limiting due to the space required to launch, recover, and loiter in the area. Also, the speed and motion of the craft would not lend to crisp and sharp images. Rocketry of out for similar reasons with a few additional concerns. If built, I will learn to fly it and fly it well as I have fixed wing craft. It’s the physics that I need to work out first. For this project to work, I need size and thrust data, motor requirements so that aprox. weights may be calculated. I have done a lot of groundwork on this concept, just would like some additional input. TIA.
    John M. Stuedle
    Aug 2003
    318
    Unfortantly I have no good input on this other than I just want to subscribe to the thread.
    I have wanted to do exactly what you are trying except I want a wireless setup on it to beam back the video and to use as a wireless access point for long range use.
    Donny
    Jun 2004
    34
    Does anyone have a feel for the total lift in lbs. of a typical .60 size rotor, and at what RPM rotor speed that lift is attained? This would give me an idea of the size electric motor and power requirements I need to factor into the design. Also, is there a line of high-end motors that have output shafts on each end? This will simplify my design. If I need to use a single shaft motor, as I think I might, I will need to include a jackshaft, and two more gears. While not a major issue, it will require 4 more bearings and the additional weight to consider.
    John M. Stuedle
    Jun 2004
    34
    “except I want a wireless setup on it to beam back the video and to use as a wireless access point for long range use.”
    Donny, for your application, there are a few camera/transmitter packages that total only a few oz. And are well within the capacity of most .30 and up size copters and fixed wing. One that comes to mind can be located at http://www.blackwidowav.com/. For my use, I want to lift a gimbaled 35mm camera, motor drive and power zoom. I have considered using the video link to see “through the lens” attached to the viewfinder, but that is third of forth generation, well down the road. At this point, I need to get past the drawing board. As I get plans together, I might scan them and post if there is any interest. (Yes, I am old school and prefer pencil/paper to CAD)
    John M. Stuedle
    Aug 2003
    318
    Thanks for the link. I'm checking it out now. If you do build this and decide to publish the plans I would be very interested in them. I have a nice cad program but still prefer to draw by hand 99% of the time.
    I checked it out and its not quite what I need. I will need a camera that zooms way in for candid wildlife shots etc. Also need to run a true wireless access point like a apple airport. Maybe a windows ce device running at 500mhz to control the Wap. Anyways. Will probley need much more power than a 0.60 chainsaw motor. Also would like electrical so that it doesn't desturb the animals.
    Donny
    Nov 2003
    459
    I wonder what your cost to develope this will be?
    What is the cost of the camera equipment?
    This may be one of those great ideas but too difficult or costly to build.
    Check this site out:
    http://www.moller.com/aerobot/
    Moller is probably the world formost expert on vertical take off, hovering and landing in one piece...
    The areobot will be used to inspect high tension power lines over unimproved locations with video.
    Keep us posted as this is a really cool project.
    Scott_bob
    Jun 2004
    34
    Thanks for the link Scott-Bob. Checked it out and his site gives you a lot to wonder about but no usable data. Apparently, his has nothing for sale at this point. As far as my cost to develop this vehicle is concerned, I already own a decent home shop, the camera equipment, a junk box of RC radio hardware and raw material. I will need to purchase gearing, bearings, sprockets, shaft material, belts and rotor blades. Time and paper are cheap, and right now I have a lot of time. My current health status requires me to exercise my mind, as that is all I can exercise. So bottom line, cash to first flight should be in the 500-1,000 dollar range. Cost afterward will depend on my skill from paper to first “touch” down.
    John M. Stuedle
    Aug 2004
    Try the web site www.runryder.com It is a forum for heli's.
    2139
    . :cheers:
    I wish it wouldn't crash.
    Oct 2004
    43
    Instead of building a machine to lift the camera, why don't you just get a smaller camera? There's some really cool small vid/cams that run on 9 volt and weigh very little. I got one from:
    www.sawtoothrc.com
    and in advance, not sure if I can post a URL here; if not please remove it.
    Nov 2003
    459
    BarnBurner,
    Way cool!!!
    Did you mount this in a RC car?
    Ever see a vitual reality set of googles that would allow you to diplay real time the video feed?
    Scott_bob
    Oct 2004
    43
    I did mount it on my T-Maxx. They have 2 videos of it on their site of a loop I made and tried to drive around. It's under the Customer Pics link.
    I had originally wanted to design a base that would work with the camera that would pan and tilt from a signal from the VR camera; basically so you could mount it on an R/C, and then turn your head to view in-car.
    Just another project/plan that didn't get started.
    Christian Guest
    I operate a helicam based on a Robbe Futura .60 turning 710mm carbon blades. I don't know about the maximum payload but I lift 2,5 kg (5.5lb) with ease. My concern is not the how much the heli can lift but how much weight it can carry during autorotation because there is allways a small risk for motor flame out using an IC engine.
    You have allready been given the Runryder address and that is a great source to knowledge in the helicam business. Go through the posts there and I'm sure you'll get yourself a proper heli instead of trying to build one.
    I think that two rotor heads just make it more complicated and also you need to think of the induced drag that will be twice a regular heli, which means that you can not just "translate" the lift capacity of a regulare .60 size engine. And you will still need a gyro to control the yaw even if you use counter rotating rotors.
    In my opinion this project will never leave your drawing table. Go out and buy a heli and have fun instead.
    Just my 2 cents
    /Christian (aka Helikalle on Runryder)
    PS. Have a look at my homepage about helicam if you like. Yeah I know it's in Swedish but the pictures are international :-). www.helifoto.se
Page 1 of 2 12
