588,468 active members*
4,944 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > M2 Steel & an Endmill Question
    Jun 2007
    73
    Two things were told to me today which i didnt believe and i wanted too see who was correct.
    1. I ordered a M2 hss lathe tool blank from mcmaster. The shop tech said that it could not be ground and it could only be EDMed. I couldve sworn i have successfully ground these several times before. Can you grind M2 tool steel on a non-diamond wheel?
    2. are endmills case hardened?
    Jan 2006
    2985
    1. yes they can be ground quite easily.
    2. not sure but it would make sense. Hard cutting edge and ductile core.
    Matt
  1. Simple question: Hot roll vs cold roll steel
    By CuttersCov in forum MetalWork Discussion
    Last Post: 01-10-2013, 02:42 PM
  2. ok total newbie question i have looked hard & everywhere for carbon steel
    By stevef12005 in forum Uncategorised WoodWorking Machines
    Last Post: 12-08-2007, 05:47 PM
  3. Shorten My Endmill
    By DroopyPawn in forum CNC Tooling
    Last Post: 11-13-2007, 01:05 AM
  4. Steel Tubing specification question
    By ad_bfl in forum Mechanical Calculations/Engineering Design
    Last Post: 10-24-2006, 10:31 PM
  5. 3/8 Ball Endmill in Tool Steel
    By Freddy in forum Hard / High Speed Machining
    Last Post: 09-08-2003, 09:13 PM
