586,461 active members*
3,399 visitors online*
Results 1 to 6 of 6
    Sep 2007
    34
    Servo as a spindle drive motor
    Hi all, can a servo motor be used as a spindle drive motor. I have never seen one used and for the life of me (or is that my limited knowledge) I can't work out why. I've googled it but nothing comes up that even points me to the right answer.
    Yes, they can. You probably don't see them often because powerful servos can be pretty expensive.
    Mar 2004
    1543
    Did you know you can make an ordinary DC motor into a servo motor? This idea would work well for a small hp. spindle drive.
    http://www.truetex.com/servomod.htm
    Karl
    Jan 2006
    738
    Servo speed
    A servo motor's maximum RPM may be a limiting factor if you are direct driving.
    I considered using a vacuum cleaner motor as a spindle motor. Reasonable power and high RPM. Speed control is easy with an autotransformer.
    Steve
    24223
    Quote Originally Posted by Allyd1964 View Post
    I have used both DC brushed and BLDC servo's for this type of app.
    If you use a Brushed servo, you can use the cheaper SCR control as made by KB , Baldor etc, these generally have the tach option included, and many DC servo's have a tach, this enables quite precise speed control.
    If you get one that is a bit higher torque than normally needed, you can gear up to get the higher speed, DC servo's are usually restricted to 3000rpm BLDC go up to ~6000rpm.
    Al.
    Albert E.
    Jan 2006
    156
    I have 3 big servo motors, brushtype,probably very old. For an experiment
    I hooked one up to an 180 V dc drive and at that voltage the motor
    turned 7800 rpm. At that point the little generator winding at the back
    of the motor started to smoke and I shut it down. The motor windings
    were fine. My opinion is that any of these motors would make good
    spindle motors. It probably would not be wise to run them at that high a
    voltage.
  1. Using surplus servo motors as spindle drive
    By Swede in forum Servo Motors / Drives
    Last Post: 03-16-2008, 02:05 PM
  2. Simens AC servo, VFD Spindle drive?
    By mikec8100 in forum Phase Converters
    Last Post: 09-26-2007, 02:30 AM
  3. Can MACH generate +/- 10V to control SERVO spindle Drive?
    By cjchands in forum Mach Software (ArtSoft software)
    Last Post: 07-23-2007, 03:58 AM
  4. mitsubishi spindle servo drive
    By intermax in forum Servo Motors / Drives
    Last Post: 11-03-2006, 04:15 PM
  5. need servo motor drive
    By Karl_T in forum CNC Machine Related Electronics
    Last Post: 11-28-2005, 04:37 AM
