588,138 active members*
6,832 visitors online*
    Jan 2007
    4
    Lathe VFD conversion
    Hello,
    I want to convert a Prazi SD400 (8x14) lathe to variable speed, without a loss of torque at slower speeds. The current motor is 1/2 hp. What would be the best VFD/ 3ph motor combination to accomplish this task. Thank you for your replies.
    Greg M.
    Jan 2006
    738
    Did you change the motor already? The stock SD400 has a 1/3 horse motor.
    Take a look here for a Hitachi drive.
    http://www.wolfautomation.com/Produc...roductID=17539
    When you look for a motor, make sure to specify that it will be running on a VFD. Not all motors do well on VFD's
    Steve
    Jan 2007
    4
    Steve,
    Thanks for the reply. I was planning on getting a larger inverter duty motor (1HP) to maintain enough torque at slower speeds. Trying to figure out if a larger motor will fit on the machine properly. Maybe this is not necessary with a sensorless vector drive.
    Greg M.
    Dec 2006
    118
    Wow i am glad i looked at this post...i had no idea i could get a vfd with a 120v input that produces 3 phase at three hoursepower!
    I don't give a damn if you don't like me, cause i don't like you cause you are not like me.
  1. So.. Who's CNC lathe conversion kit to purchase and why?
    By turbostang in forum Vertical Mill, Lathe Project Log
    Last Post: 01-03-2008, 06:24 AM
  2. Bench lathe Conversion Kit
    By tootalew in forum Mini Lathe
    Last Post: 03-08-2007, 07:11 PM
  3. Manual lathe conversion to CNC -
    By jdmech in forum Uncategorised MetalWorking Machines
    Last Post: 10-02-2006, 10:32 PM
  4. Mini lathe conversion
    By kdoney in forum Uncategorised MetalWorking Machines
    Last Post: 08-27-2004, 04:21 AM
  5. CNC lathe conversion (again, sorry!)
    By kong in forum Uncategorised MetalWorking Machines
    Last Post: 03-27-2004, 08:06 PM
