586,588 active members*
2,513 visitors online*
Results 1 to 9 of 9
    Apr 2004
    CAM recommendations
    Looking for recommendations for CAM packages please.
    Using Solidworks to generate models.
    So far I am considering Camworks, Hyper Mill, Solidcam, and Mastercam.
    All I need a 2 axis mill package that I'll use once a week. Currently using a DXF converter on a Prototrack but that takes a long time to get a good tool path.
    Matt
    Jan 2007
    869
    Check out Dolphin Cad/Cam. It's quick and easy to use. It's 2.5d, which sounds pretty muck like what you need. www.dolphincadcamusa.com
    Hope this helps.
    Wade
    Jan 2004
    3154
    You should look at SprutCam and VisualMill 6.
    Those high dollar companies you are looking at are financially wasteful for 2.5d machining.
    The makers of VisualMill have a package called FreeMill which would likely suit your needs, well, for free.
    For 2.5D CNC work out of SolidWorks I find it quickest/easiest to save a 1 - 1 drawing as a dxf/dwg and send that to CAM. Sending solids or surfaces to CAM almost always takes twice as long to generate code from.
    www.integratedmechanical.ca
    Oct 2007
    499
    For what you want, I would check out either OneCNC or CimcoEdit V5 with CNC Calc. You get a lot of programming power for you money.
    Jun 2003
    11
    Since your already familiar with the SolidWorks interface, why not look at the Gold partners. I believe Openmind (Hypermill) is located fairly close to where you (and I) live, and they have local engineering which is always a bonus.
    Dec 2007
    617
    Hi:
    I used to use Mastercam, until I tried SolidCam. Seamless interface, as it's a gold partner solution. Very easy to use. I never use Mastercam anymore.
    regards
    Apr 2004
    Had a Camworks demo today. Nice looking package. Gave the guy a nozzle plate part we make. Its 12 airfoil islands arraigned in a circle. It took five minuets to generate a tool path and then some computer time to post it. Threw it on the Prototrack and we could have been cutting. Normally that would take us an hour plus to get done.
    Thing about the Solidworks based programs I like is when I rev a part all I have to do is regen the tool path and repost. Plus I'll only have one post file to link to the part in PDM to have in under rev control.
    Still looking at Solidcam and Hyper Mill. I promised the guy from Camworks that I'd give them the same part to work with.
    Thanks for all the input.
    Dec 2007
    617
    Hi:
    Just an opinion, but work with the CAM provider that has demonstrated support, ie post processor programming etc. The weakness I found with SolidCam was an abject lack of support (Local and national for Canada). We purchased a VMC with a Fagor 8055 Control, and ended up having to write our own post, because they could not provide one. Excellent product - no support=lost revenue. Unfortunately the product itself is really good (intuative), and leverages your machining knowledge.
    Apr 2006
    130
    Hi Matt:
    OPEN MIND (hyperMILL) will service you directly in NH from our Boston office.
    And our company background originated with CNC controllers, so our solutions, engineers, and PP are very practical and machine-oriented.
    You will also find us very price competitive in 2D/3D. So the high price comment above is really from someone that hasn't taken a close look lately.
  1. Need some recommendations
    By DragnsBane in forum CNC Machine Related Electronics
    Last Post: 01-31-2007, 10:11 PM
  2. Controller recommendations
    By searcue in forum CNC Machine Related Electronics
    Last Post: 06-04-2006, 11:40 PM
  3. VFD recommendations?
    By split63 in forum Uncategorised MetalWorking Machines
    Last Post: 05-27-2006, 10:39 AM
  4. TIG recommendations?
    By nervis1 in forum Welding Brazing Soldering Sealing
    Last Post: 04-17-2005, 06:50 AM
  5. CAM Recommendations
    By Benjamin in forum Uncategorised CAM Discussion
    Last Post: 09-08-2003, 04:32 AM
