603,795 active members*
3,492 visitors online*
Results 1 to 6 of 6
    Feb 2008
    33
    Mach3 Wont Run - Setup Help
    Hi All my First Post!
    i have been working for 2 weeks trying to get mach3 to run my controller and motors
    im using windows 2000
    mach3 loads no problem
    i have done this:
    Entered Bios Port Setting "SPP 378"
    Gone to ports and pins in mach3 changed port 1 into "0x378" Clecked port enable, kernel speed = 25000Hz Port2 disabled
    Motor outputs x,y,z enabled (Green ticks)
    The cnc controller is made by damen cnc and came with the pin set up
    PIN:1 spindle
    PIN:2 DIR X
    PIN:3 STEP X
    PIN:4 DIR Y
    PIN:5 STEP Y
    PIN:6 DIR Z
    PIN:7 STEP Z
    ETC.....
    Then in motor out puts i haved used that to changed the step pin# and Dir pin# & DIR low/active enabled & STP low/active
    Still Nothing, Mach3 shows that the motors should be running (Simulation) but the motors dont move, i have all the correct lights on my controller has full power, i have set up the E-Stop so mach3 resets and have used mach3 set up guide to the TEE!!
    i know theres just one little setting that i have missed or a setting!
    i know my controller works and motors as i have used in using kellycam on another pc
    any help would be great!
    osha
    Jul 2007
    887
    First you need to make sure that 378 is the correct adress. Second you say that the controller work on another computer, that's good. The problem could be that the parallelport on this computer only outputs 3.3V and the controller needs 5V (laptop by any chance?)
    If you have a voltmeter please meassure between ground (pin18-25) and pin2 (X-DIR) of the parallelport. Then jog in one direction, you should see very close 0V when jogging in one direction and close to 5V when jogging in the other.
    /H.O
    35494
    enter 0378 as the port address
    Aug 2005
    86
    Cosha,
    Does the Damen CNC board use opto isolators to protect the PC?
    If so you may want to run - sherline mode (it's a check box setting in the setup area)
    Apr 2006
    113
    Make sure the mach driver is installed...look in the system files....another gentleman had that same promblem and that was the cause...
    jim
    Feb 2008
    33
    Smile
    Hi all thanks for the replys!
    sorry its taken a long time to respond (im a weapons tec for the mod and i been working stupidly hard recently)
    ok i started from scratch again!
    Bios SPP mode 378
    Re installed Mach3
    Re installed Drivers
    Configured Out Everything!
    Still NOTHING!
    Then In Ports and pins Motor Options, i replaced the ports used to all Number 1's as i was using that port selection - Still Nothing
    Rebooted and....
    ITS WORKING PERFECTLY! PHEW!
    i Knew It Would Of Been something small that i missed out!
    i used a MACH3 set up help file and i cant remember it saying to set up the ports to all 1's!
    Thanks everyone for your help!!
    Cant wait untill the rails and lead screws get here in a few days!!!
    Thanks Again!
    I Hope somone reads this who has the same problems to check on it!
    EDIT - just watched the mach3 help video - DOH it says it clearly....how did i miss that!!
  1. Is this a good PC setup for Mach3 ?
    By cnczoner in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 06-26-2007, 02:25 PM
  2. Syil X2 setup with Mach3
    By 43hudson in forum Syil Products
    Last Post: 03-27-2007, 01:52 PM
  3. More Mach3 Setup Questions
    By bill south in forum Mach Mill
    Last Post: 05-08-2006, 04:10 PM
  4. Mach3 setup
    By mlaws1172 in forum Mach Plasma / Laser
    Last Post: 11-30-2005, 05:14 PM
