603,897 active members*
5,777 visitors online*
Results 1 to 7 of 7
    Oct 2006
    36
    Parallel Port Adapter?
    I am shopping for a new laptop to run my SX3. Can't seem to find one that has the parallel port, does anyone know if the USB to parallel adapter works on the SX3? If so, how would you assign pins? Thanks Brian
    Feb 2008
    33
    No, a USB to parallel printer adapter won't work. This month the SmoothStepper is set to be released, it will drive the steppers using a USB port and Mach3. I'm thinking of getting one myself.
    http://www.warp9td.com/
    There is also the Gecko G100, it's expensive though and not near as plug 'n play as the SmoothStepper.
    http://www.geckodrive.com/product.cfm?pid=19
    Or you could shop eBay for a used laptop. Be warned though, some laptops won't work right with Mach3 even if they have a parallel port.
    Feb 2007
    25
    Brian,
    as presslab states - a USB adapter won't work. What will work though, is a PCMCIA / Parallel Port adapter. You shouldn't have any trouble finding a laptop with this kind of slot.
    Here's a link to the adapter that I purchased in the UK and which might be useful for UK X3 users:
    http://tinyurl.com/2w3etn
    Hugh
    Syil.UK
    Feb 2008
    33
    Ah, I didn't think of that! That's a good one.
    I have two laptops, both with parallel ports. One of them doesn't work well at all, the steppers grind and bump no matter what I did. The other worked better but it had the occasional bump which would stall the steppers. I removed the battery from that one and now it works very well. I am getting 100 ipm easy from X, Y, & Z.
    Jun 2007
    78
    Quote Originally Posted by hughlss View Post
    Brian,
    Hugh
    Syil.UK
    I'd like to run my laptop purely as a back up for the dedicated computer on the X3 and have tried a PCMCIA parallel port adapter with limited success. It has 1.7mbps data transfer rate & while it will talk to the X3 any stepper movement is slow & sounds very painfull.
    Will the extra data rate of the card you use fix the problem or should I be looking elsewhere????
    Apr 2006
    844
    a thread of chinese was clear indicate PCmcia can be use on MACH.
    here it is orignial words,i try to translater,my english not very well.
    并口输入输出地址是FD98-FD9F,默认的端口号是LPT3,可以修改成LPT2,在MCAH里选择LPT2,然后修改下输入输出地 址就可以用了。串口的默认端口号是COM3,也可以修改成COM2。原来主板带的是COM1和 LPT1。
    adjust parallel out/input address to FD98-FD9F,and default port number it is LPT3 and adjust it to LPT2,then change MACH config to LPT2,Serial port default it is COM3,and change it to COM2.original mainboard default usually is COM1 or LTP1.
    some pic attach too...
    Attached Thumbnails Attached Thumbnails 20082281747000.jpg   20082281747011.jpg   20082281747012.jpg   20082281752040.jpg
    Direction,Commitment,Follow through
    Nov 2006
    9
    chiness express card to serial port adapters
    chiness adapters for vista 32 or 64 suck! cowboy up and buy a good one. i got a cheapy that said it was compatible but wasn't. how did things work out for you?
  1. C++, Win XP, Parallel Port
    By Zumba in forum Coding
    Last Post: 03-29-2012, 07:12 PM
  2. ExpressCard Parallel adapter?
    By GMTool in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 03-25-2008, 05:41 AM
  3. Second parallel port?
    By essa in forum LinuxCNC (formerly EMC2)
    Last Post: 04-12-2006, 08:18 AM
  4. usb to parallel port adapter
    By mmech in forum CNC Machine Related Electronics
    Last Post: 03-09-2006, 08:58 AM
  5. Parallel Port
    By Shanghyd in forum Computers / Desktops / Networking
    Last Post: 11-22-2004, 06:56 PM
