586,655 active members*
4,051 visitors online*
IndustryArena Forum > OpenSource CNC Design Center > Open Source Controller Boards > Open Source Boards Available, Stepper Drivers and Break Out Boards
Page 19 of 39 9171819202129
Results 361 to 380 of 763
  1. #361
    Mar 2004
    18
    Hi Phil, didn't see the updates, I am looking at http://webpages.charter.net/pminmo/cncelectronics.htm
    Are they at another site??
  2. #362
    May 2004
    200
    alot of info here.. but Im confused at this point.
    is there a
    bipolor controler board, chopper board and a 1/4 or 1/8 stepper board?
    Tek
  3. #363
    Mar 2004
    222
    tekno, I think the 297/298 combo is a chopper full - 1/2 step board, the a3977 board from Phil's site is also a chopper board that do microstepping.
    mhel
    "This is intentionally left blank."
  4. #364
    May 2004
    200
    Quote Originally Posted by slp_prlzys
    link to Phil's site please
    And thanks
    Tek :cheers:
  5. #365
    Mar 2004
    190
    Phil's site is at post #361
    /Fer
  6. #366
    Jun 2003
    3312
    Actually they Benny made an active page out of post #1 of this thread.
    Phil
  7. #367
    Jun 2003
    3312
    Timewarp,
    Try forcing a refresh on your browser, they are there.
    Phil
  8. #368
    Jun 2003
    3312
    To those interested/affected
    I pulled the 3 axis interface board off my website and just left the 4 axis (of course it can be used with 3 axis or 2 axis or 1). Reason, just easier to support one board. If your headed down the old 3 axis board path, I still have the data and will be glad to answer questions, email files, etc. There is some documentation started now for the 4 axis board. If a person wants to leave off the 4th IDC pin header (less than a buck) there is little cost difference to build, so to me it just makes sense. Plus look at all the posts where people are building 4 axis to use on their 3 axis machines! (GROWTH POTENTIAL!) Unless otherwise talked out of it, I'm probably going to reduce the number of files on my website. Basically for each board going to one pdf documentation file, which will have a schematic and layout in it, one pdf file for copper, and possibly leaving a pdf schematic also. Trying to organize, unclutter the webpage and free up some webspace. Thoughts?
    Phil
  9. #369
    Oct 2003
    593
    Sounds like a good idea. It will make it easier to see what's what at a glance.
    Do you have any plans for a PIC microstepping driver in the works. I know there are one or two mentioned on the "zone". You seem very active, supportive & regular updates. Would be nice to see a microstep driver.
    Great job so far. Look forward to more of the same please.
    Regards Terry...
  10. #370
    Jun 2003
    3312
    MrBean
    Actually there is one microstepping driver on the site. The A3977 (although I wouldn't recommend it to anybody that is not highly knowledgable of electronics), and the L297-298 board.
    Also, Pigifly has finished a one sided layout for the L297-8 board and has started a new thread on the ZONE here:
    http://www.cnczone.com/forums/showthread.php?t=6339
    The L297 will do half steps. What is your primary reason for wanting microsteps, resolution, quietness? Because there are some downsides of microstepping also. I can't say that I have found a good reason for a cnc size machine to do microsteps for the tradeoff.
    Phil
  11. #371
    Oct 2003
    593
    My motors resonate/vibrate quite badly at certain speeds as my boards are full step. Extra resolution of microstepping would not be required, but it's there anyway.
    What I require that my current boards do not give me is:
    Current limiting (Chopper)
    Quieter/smoother running
    Maybe 1/2 steps would reduce the vibration a bit?? The 297-8 would also give me current limiting.
    Would you say that half stepping would be enough to reduce the vibration. If so, I'll maybe have a bash at building the 297-8.
    Regards Terry...
  12. #372
    Jun 2003
    3312
    Terry,
    A chopper alone may solve your problem.
    Phil
  13. #373
    Mar 2004
    222
    half step does make a difference, I built the discrete board full step, and the UCN5804
    version full/halfstep capable, and I like the smoother motion with the 1/2 step of UCN5804, less noise.
    mhel
  14. #374
    Jun 2003
    3312
    slp,
    long time no hear from, how's it going?
    Phil
  15. #375
    Jun 2003
    3312
    ITO,
    What about this FET STP30NE06.
    Phil
  16. #376
    Mar 2004
    222
    Phil, yes hi,
    I got hook with the picmicro thingies,
    I'm trying to build a plotter/vinyl cutter, like on Luberth.com site, as
    it is considerably quiet in operation, compare to cnc router.
    I built the prototype for pstep board, based on the pictures on the site,
    I can now blink a led using serial port I'm now attaching the discrete board
    to it and see if I could step it.
    mhel
  17. #377
    Jun 2003
    3312
    slp,
    Great, sure you don't want to change your studies to electronics? No help here on the PicMicro's, but AVR I can.
    Phil
  18. #378
    Mar 2004
    222
    OT: I'm actually trying to learn more of electronics now,
    I'm eyeing to buy a books authored by Horowits & Hill,
    'seems highly recommended, I'm just trying to build
    something useful for extra income, it's "earn while you learn thing".
    mhel
  19. #379
    Aug 2004
    170
    Hi guys i need some help on my DISCRETE project:
    is that right? i send a picture from the pcb lay-out an i saw something diferent...
    please help me, because i will mount my first discrete driver this week end!
    thanks a lot!
    Other thing: may i use the "green areas" to personalize my pcb, like put a name, a number etc...????
  20. #380
    Jun 2003
    3312
    Ito, that is correct. I downloaded my website eagle .brd file and its the same as my local file. Pins 6, 7, and 8 are all grounded. Yes you may use the green area for anthing you please.
    Phil
  1. Best break out boards?
    By Nigel Tufnel in forum Stepper Motors / Drives
    Last Post: 12-27-2013, 07:12 PM
  2. Dual Break out boards
    By ynnek in forum DIY CNC Router Table Machines
    Last Post: 07-11-2013, 04:34 PM
  3. Break out boards...
    By kiwichris in forum LinuxCNC (formerly EMC2)
    Last Post: 11-06-2012, 10:20 PM
  4. Servos, drivers, break out boards
    By HereinCS in forum Servo Motors / Drives
    Last Post: 08-13-2010, 06:09 PM
  5. PC parallel port break-out boards
    By widgitmaster in forum CNC Machine Related Electronics
    Last Post: 09-20-2005, 01:47 PM
