587,702 active members*
3,453 visitors online*
Results 1 to 18 of 18
Hybrid View
    Feb 2008
    8
    milling a chamfer with endmill
    Hi everyone, I'm new here, so be nice if I'm in the wrong section or my question has been exhausted already. Trying to mill a 2.5d chamfer on a cnc mill with a ball nose end mill. Is there a canned cycle that can be programmed for this or do I have to figure out compensation line by line?
    Any help would be great. Thanks...
    Quick
    Mar 2005
    988
    There might be a macro out there for it or just program it on a CAD/CAM. But for what its worth, its a lot of "work" and cycle time. Couldn't just use a chamfer mill?
    It's just a part..... cutter still goes round and round....
    Jul 2005
    12177
    Change to a chamfering tool and do your chamfer in a single pass.
    One of my guys wanted to prove that he could do chamfering, with a corner radius mill I think it was, and avoid a tool change; so he wrote a macro to step down the chamfer. It worked....and took so much time the machine could do a dozen tool changes.
    May 2005
    2502
    Quote Originally Posted by Geof View Post
    How was the surface finish?
    Do you ever run 4 or 5 axis just because thinks work better if the cutter can stay normal to the work?
    Cheers,
    BW
    Jul 2005
    12177
    Quote Originally Posted by BobWarfield View Post
    Cheers,
    BW
    Surface finish? Not as good as using a chamfering tool.
    No we do not do 4 or 5 axis. We use the 4th axis for positioning only. All our parts are designed for 2.5 or 3 axis machining.
    May 2005
    2502
    That's what I would have expected, faster + better finish with a tool built for it, or, if you could position the workpiece so the tool cuts the chamfer while normal to the cut.
    I do wonder if 4 and 5 axis doesn't give you those advantages too. Just an OT/academic sort of question.
    Cheers,
    BW
    Mar 2005
    988
    A chamfer tool works as long as the chamfer is no bigger than the tool.
    Get a bigger chamfer tool ...
    Yes it can. With higher feeds and better finishes. Using chamfers as an examples.... Most will have a limit to feed before finishes starts to look chattered even with multi flutes because of the diameter change in the cutter (from the "small" end to the "big end"). Picture the same operation on a 4/5 axis and using the side of an endmill or bottom of one. Programmable diameter and chip loads can be much higher while attaining good finishes. The principle is the same for draft angles and such. The same endmill can do an "infinite" number of angles. Now, I'm not saying this would replace the chamfer mill in all 4/5 axis work... it most certainly does not. But optimization and utilization is opened greatly.
    Nov 2006
    174
    I was hoping for a repeating pattern
    I'm not sure what you need to chamfer but if it's the top of a hole, try this...good old "do/while" loop.
    Work out your start position and trig out your chamfer angle to get your increments. 45 degrees is easiest!!
    (METRIC PROGRAMMING)
    M6T1(whatever ballnose)
    G0X10Y0G54S3000M13 (rapid to start pos)
    G43Z10H1
    #500=10 (start pos in X)
    #501=0 (start pos in Z)
    WHILE[#500GE-5]DO1 (start of loop which ends at Z-5)
    G1X#500Y0Z#501F1000
    G3I-#500
    #500=#500-0.2 (increment amount in X)
    #501=#501-0.2 (increment amount in Z)
    END1
    G0Z10M9
    G53Z-100Y0
    M30
    Traa-Laa...one chamfered hole (took a while though!
    if its multiple tool changes your trying to prevent then i would say if your going to be doing any drilling on the part use a 90deg spot drill for spotting any holes and use that same tool to run your chamfer
    A poet knows no boundary yet he is bound to the boundaries of ones own mind !! ........
    Mar 2005
    988
    ..... or you could spot your holes with the chamfer mill and then run the chamfers with it ......
    Quote Originally Posted by psychomill View Post
    as long as the tool comes to a point or it could get pretty ugly
    ingersol has a nice single flt chamfer mill with a trangular insert which works good for doing that kind of stuff,
    the magic of using a spot drill is you've got twice the flt which means twice the feed , they are generally a smaller dia than a mill which makes it easier to get to hard to reach places ,its one less tool holder to search for and one less tool change , plus they're dirt cheap disposibles
    Mar 2005
    988
    Yeah... didn't think about the different types of chamfer mills out there....
    But these are the types I was thinking of. Spot and chamfer....
    wasn t sure if you were kidding with me about running the chmf mill or not
    those are nice looking cutters you posted ,nice production tool ,
    due to the nature of most of the work ive been doing the past few of years i have grown so accustomed to using insert tools that a solid carb chmf mill was far from my mind
    Mar 2005
    988
    Hell, I thought you were kidding with me! :stickpoke That's funny...
    Well, let me tell you, you have to get into these. Several companies make them such as DataFlute, Helical Solutions, Destiny Tool, New Tech (Swift Carb), Harvey Tool, etc, etc, etc. The common sizes are from 1/8 to 1/2" on 45° (90°) or 30°(60°), 2 or 4 flute, coated or uncoated, etc. Some of them make 3/4 and 1" sizes, other common angles like 82° or 120°, etc. Most of them are ground to a "point" that's gageable and programable based on the theoretical sharp point..... and they'll all spot drill. Go get'em....
    :cheers:
    Jun 2009
    11
    Re: milling a chamfer with endmill
    You don't need a ball nose bit or a chamfer bit if your software has a fluting toolpath. I make chamfers on bolt holes using the same end mill I use to drill the holes.
    https://4dfurniture.blogspot.com/202...-end-mill.html.
    Saves doing a bit change on my CNC with no ATC.
    Attachment 486696
    4D
  1. milling a big chamfer with siemens control
    By russellthackray in forum SIEMENS -> GENERAL
    Last Post: 05-15-2015, 04:14 PM
  2. 3 axis milling operation with a chamfer mill?
    By Brian Corwin in forum BobCad-Cam
    Last Post: 03-10-2014, 07:16 PM
  3. milling a chamfer
    By russellthackray in forum FeatureCAM CAD/CAM
    Last Post: 06-02-2012, 05:23 PM
  4. Chamfer milling speed data?
    By JMFabrications in forum Uncategorised MetalWorking Machines
    Last Post: 09-13-2007, 06:30 PM
  5. Milling 37 degree chamfer around a circular piece...
    By peter.blais in forum MetalWork Discussion
    Last Post: 09-20-2006, 06:47 PM
