586,108 active members*
2,994 visitors online*
IndustryArena Forum > Community Club House > International / Regional Forums > Canadian Club House > Please Help!3 Axis Milling-How to adjust Z value so it doesn't cut above the material
View Poll Results: How to adjust Z value so it doesn't cut above the material
Voters
3. You may not vote on this poll
  • HELP - Cutting from toolpath with rhino generated tool path
    1 33.33%
  • HELP CNC running toolpath in the air
    2 66.67%
    Mar 2008
    5
    Exclamation Please Help!3 Axis Milling-How to adjust Z value so it doesn't cut above the material
    Hi I am in the process of learning milling in 3d on the school's 3 axis axyz cnc machine.
    The model and tool path are generated in Rhino and imported to tool path.
    Q: In toolpath output, what do I input for DEPTH ?
    I have tried setting it as 0, 1 , etc. When I run it, the machine runs the tool path about the stock.
    Please help me ! Greatly Appreciated !
    Aug 2007
    135
    In CAM, output the proper code. That is, have it go to the proper depth of cut as if you were really cutting metal. On the machine, edit the work coordinates (where you set up your XYZ on the part) and bump the Z wear offset up enough so that your deepest cut is up above the metal.
    The Machinist's Chatroom
    http://machinechat.freehostia.com/
    Jan 2004
    3154
    1st you need to know where the Z offset of your tool is set. I am assuming you or someone set the tools up when installing them in the machine, if not run away, because I guarantee you are going to crash the machine.
    In CAM software you position your stock relative to it's position to Z zero in the real world. Now you can set your depth of cut and have it work.
    EG if your cutter offset (on the machine) is set to zero on the table. and your part to be cut is an a vise - lets say the top of the part is 5" above the table.
    If you have tool 5 in the spindle - then to position the tool exactly on the top of the part your code should be G0 G90 H5 Z5.0(H5 tells the control to use the height offset for T5(this may be what you are overlooking in RhinoCAM BTW)).
    So to cut .5" deep in this part your Z height in the actual code will be 4.5".
    It will take another 2 pages to explain the CAM setup, so you can check this stuff 1st and repost.
    www.integratedmechanical.ca
  1. Milling Durastone material using CNC
    By arazelan17 in forum Glass, Plastic and Stone
    Last Post: 04-23-2013, 04:53 AM
  2. Cutting G10 material without metal tools? (CNC milling)
    By burnthills in forum MetalWork Discussion
    Last Post: 11-01-2006, 08:34 PM
  3. material to practice milling
    By xovationx in forum Material Machining Solutions
    Last Post: 03-21-2006, 04:54 PM
  4. Milling a very hard material
    By arazelan17 in forum MetalWork Discussion
    Last Post: 02-16-2006, 06:09 AM
  5. Pocket Milling - Less Material
    By Natchamp in forum Visual Mill
    Last Post: 09-12-2005, 02:21 PM
