587,047 active members*
2,471 visitors online*
    Feb 2007
    514
    Plasma Home Position
    What is the normal home position for a plasma table?
    Do you normally cut in the X and Y positive quadrant (quadrant 1) so the sheet is 0,0 on the front left of the material?
    On my mill I normally cut in quadrant 4...
    I'm almost done with my machine and I want to set it up the same as normal ones. I could actually cut today if I wanted YEA!
    John
    Jan 2007
    599
    im used 0,0 being at the right front of the machine. but it differ from machine to machine.
    Feb 2006
    1260
    My Home 0,0 is front left. If it were me I'd make 0,0 where it is most convienient to operate based on location in your shop, other equipment etc.
    If it works.....Don't fix it!
    Feb 2007
    514
    I was thinking that front left would be the most intuitive. I'm figuring that most cuts will be in the front as the machine is portable and after chewing up part of a sheet most likely I will trim the front edge square before quitting for the day.
    John
  1. Home Position
    By Mooser in forum Tormach Personal CNC Mill
    Last Post: 03-26-2008, 04:30 PM
  2. TL2 Would Not Find Home Position
    By Geof in forum Haas Lathes
    Last Post: 01-25-2008, 04:21 AM
  3. Home Position Fanuc OM-C
    By Derek.C in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 01-28-2007, 08:06 PM
  4. New guy questions home position
    By washingtondude in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 04-19-2006, 03:46 AM
  5. Home switch position
    By MrBean in forum DIY CNC Router Table Machines
    Last Post: 12-17-2004, 01:00 AM
