586,075 active members*
3,691 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > First Router Build, Is The Frame "Beefy Enough"
    Apr 2008
    Hey there, I'm currently designing my first CNC from 50x25mm, 3mm rectangular box section. My CNC bed is 1000x500 I'm wondering if my frame will be stiff enough. Here is a render of how its going to be built. All bolted with mainly M5 bolts. The legs are made from 50x50mm 2.5mm thick square box channel.
    This might sound like a silly question but will an M5 bolt fit in a 5mm Hole?
    Thanks, James
    Apr 2008
    I forgot to mention. Im going to add a cross member to bolt the legs together on each side.
    Quote Originally Posted by jimbooboo View Post
    Yes, it will.
    You might want to look at how this machine was built.
    http://www.cnczone.com/forums/showthread.php?t=30751
  1. Replies: 14
    Last Post: 11-13-2015, 02:57 AM
  2. "low end" HF Spindle or "high end" router for about $1000?
    By biomed_eng in forum DIY CNC Router Table Machines
    Last Post: 01-06-2012, 07:15 AM
  3. My "S.H.I.G." router build starts
    By picbits in forum CNC Wood Router Project Log
    Last Post: 05-12-2008, 06:48 PM
  4. Want to build CNC Router for routing 3/4" MDF and solid wood
    By Darren_T in forum DIY CNC Router Table Machines
    Last Post: 10-16-2006, 02:31 AM
  5. Need recomendations on 2" square steel tube for router frame.
    By danm in forum DIY CNC Router Table Machines
    Last Post: 11-15-2005, 01:21 AM
