603,781 active members*
2,648 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > Changing the default post processor...
Results 1 to 9 of 9
Hybrid View
    Jan 2008
    26
    Hello!
    Does anyone know how to change the default post processor in Bobcad rather than having to select the correct one each time bobcad starts up?
    I'm using Mach 3 - Metric.MillPst.
    I've tried editing millingmachinesetup.txt then running the ToBin.exe, but have had no luck (probably as I don't have a clue what I'm doing, just re-naming & deleting everything!).
    Any help would be much appreciated!
    Oct 2007
    142
    I asked this same question yesterday while on the phone with tech support. It is possible but after he told me everything I had to do, I just delete all the other posts.
    Jan 2006
    4396
    CAM Menu
    Right click Milling Tools>Current Setting>Posting>Select a Post Processor then you should be good to go
    Toby D.
    "Imagination and Memory are but one thing, but for divers considerations have divers names"
    Schwarzwald
    www.refractotech.com
    Oct 2007
    142
    Cool
    Quote Originally Posted by tobyaxis View Post
    CAM Menu
    Can I call you next time instead to tech support?
    Jan 2006
    4396
    Quote Originally Posted by orizaba View Post
    My office number in on my website www.axiscncprogramming.com
    Toby D.
    Schwarzwald
    Aug 2003
    449
    This is a one time fix. In order to have the system always choose the same post upon opening you need to edit the MillingMachineSetup.txt file.
    Just replace the post on the first machine, which is usually the default, with the name of your post processor. The only thing that you need to make sure of is that your post name does not have any spaces. This means both the .MillPst file and the reference you put into the MillingMachinesetup file.
    There is a thread on the BobCAD support forum that details the editing of the MillingMachineSetup file. I would check there. I forget the exact link, but if you need me to I can try to find it again.
    Regards
    Jan 2008
    26
    Thanks! Easy when you know how ;-)
    Jun 2008
    1838
    Re: Changing the default post processor...
    No need to go editing your .xml file, simply go to "Cam Defaults > Current Settings > Select Posting > Select your Post in the Library > Select "Machine Parameters" and click the "Save as Default" button, now click the "OK" button, close BC and then when you re-open it your default PP will be the one you selected
    Regards
    Rob
    :rainfro: :rainfro: :rainfro:
    Jun 2015
    6
    Rob
    Thanks that works also
    I hadn't tried it since it was listed as "Current Settings" thinking that was for the current session not for date forward default.
    Terry
  1. Post Processor: Changing the format of feed output.
    By somebodyelse in forum CamBam
    Last Post: 01-16-2014, 03:33 PM
  2. Changing tab default size in nesting
    By Grandpa53 in forum BobCad-Cam
    Last Post: 11-07-2013, 05:11 PM
  3. changing default settings
    By routalot in forum Rhinocam
    Last Post: 09-27-2013, 08:45 PM
  4. default depths not changing
    By hatchmar in forum BobCad-Cam
    Last Post: 07-18-2012, 01:12 PM
  5. changing a post processor
    By fourperf in forum Fadal
    Last Post: 06-16-2007, 04:48 PM
