586,075 active members*
4,098 visitors online*
    Feb 2008
    553
    Question Is this interface compatible with UHU ?
    Hi every body on the forum !
    I've got a question about this parallel interface http://pminmo.com/4axisopto/4axisDIYopto.htm Is it compatible with the UHU servo driver ? or can you point me on a DIY 4axis optoisolated interface that's working with UHU's ?
    Thanks !
    cnc2.
    May 2006
    161
    The UHU controller has built-in opto isolation , so you could wire it directly to your parallel port.
    Todor
    Feb 2008
    553
    Quote Originally Posted by LZ1TWB View Post
    Todor
    Thanks for the reply man !
    since i posted,i had some info from kreutz & the guys from the diy open source controller forum & i have built this interface :http://pminmo.com/PMinMOwiki/index.php5?title=5axis
    Best regards,
    cnc2.
  1. 8020 compatible rails?
    By jseiler in forum Linear and Rotary Motion
    Last Post: 03-05-2007, 03:31 PM
  2. gecko compatible
    By dgalaxy in forum Bridgeport / Hardinge Mills
    Last Post: 06-04-2006, 05:28 PM
  3. 450 oz Stepper and Gecko 202 compatible?
    By andy_ck87028 in forum Stepper Motors / Drives
    Last Post: 12-03-2005, 04:11 PM
  4. TTL Compatible controller
    By metalhacker in forum Open Source Controller Boards
    Last Post: 05-23-2005, 06:25 AM
  5. Are CAT and BT compatible?
    By ETNOM in forum Uncategorised MetalWorking Machines
    Last Post: 12-16-2004, 02:08 PM
