603,377 active members*
3,194 visitors online*
IndustryArena Forum > Community Club House > Do you have a fast DSL? Help!
Results 1 to 12 of 12
    Apr 2004
    678
    I have tried numerous times to download user manual and configurator program for a Yaskawa SGDB20AMA. But the transfer always gets broken after about 2Mbyte. My DSL is sick, so that takes about 2 minutes.
    If you have a fast (DSL) line please try this to see if the problem is with my end or the other.
    Go to: ftp.yaskawa.de/Public/PDF_Technical_Documentation/Motion&Control/SigmaI_Series/SGDB then try to download English_User_Manual_SGDB(TSE-S800-16D).zip
    This is an appx. 11Mb file.
    If you can get it, I have more problems than just low speed here. If not, I'll try to contact yaskawa.de and ask them for advice.
    Mar 2004
    37
    I was able to download the file but after it completed Winzip said it was not a valid archive. I will try again.
    Cheers
    Greg
    Mar 2004
    37
    I tried three times but I have had no luck in downloading a valid file. I tried both English manuals and both are flagged by Winzip as an invalid archive. I opened the zip using Word and I do see a valid PDF header but unfortunately it just seems the ZIP file is broken.
    Cheers
    Greg
    Apr 2003
    1079
    i managed to download 6.9Mb before it finnished. The file seems to be corrupt.
    Apr 2004
    678
    Thanks guys.
    I'll try to contact Yaskawa.de and ask them. Since there are 3 different persons at different continents that have problems, I assume the problem is at their site.
    WallCrawler Guest
    2004-08-18 00:11:43 EST: 8298 / 935
    Your download speed : 8497828 bps, or 8298 kbps.
    A 1037.3 KB/sec transfer rate.
    Your upload speed : 957548 bps, or 935 kbps.
    WallCrawler Guest
    Go to DSL reports http://nyc.speakeasy.net/ there is great info on how to tweak your system
    WallCrawler Guest
    WallCrawler Guest
    Apr 2003
    1079
    Wallcrawler, that's got to be a record number of consecutive posts there!
    Sorry for going O/T!
    Apr 2004
    439
    they must have fixed the problems as i download
    and it unzips fine for me. maybe if you're still having a problem i can break the zip into 10 1mb files for you?
    6855
    Quote Originally Posted by kong
    That's one way of increasing post counts.
  1. Dancin' as fast as I can boss...
    By lsfoils in forum Safety Zone
    Last Post: 09-19-2005, 08:31 PM
  2. Speed how fast an axis can move?
    By jlagran he in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 01-05-2005, 05:05 AM
  3. Rapid Traverse Too Fast
    By gopackgo in forum Mach Software (ArtSoft software)
    Last Post: 11-25-2004, 06:50 AM
  4. Running with a wave driver , too fast?
    By Konstantin in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 03-30-2004, 11:11 PM
  5. IPT too fast for old equip
    By inthedark in forum Uncategorised MetalWorking Machines
    Last Post: 01-14-2004, 03:17 PM
