586,822 active members*
3,333 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > LinuxCNC (formerly EMC2) > getting a file from the drawing to the machine
Results 1 to 9 of 9
    Apr 2008
    5
    Hi i'm a newbie to cnc. I'm using emc2 software and I have no trouble getting the examples to work. My question is how do I get a drawing from whatever software i'm going to use to the .ngc file format that emc likes.
    Apr 2005
    1778
    I use emc2 also. I started out using NCPlot2 under Windows to convert a DXF file to gcode. I also have VCarve for fancy engraving, but most of the time I just write the gcode by hand.
    Alan
    Apr 2008
    5
    Thanks for the reply. I guess I'm just lazy but not into writing all that code. Is there a good software program for windows to draw or create what you want, then convert to the emc2 format?
    Apr 2005
    1778
    I generally try to avoid Windows like the plague, but there are a number of CAD programs for Windows and NCPlot or VCarve will import a DXF file and produce output for emc2. Vectrix also sells Cut2D and Cut3D programs, Vectrix has a post processor that works for emc2.
    You can get a free demo copy of QCAD for Linux, Mac or Windows and the license fee is only 35-40 dollars.
    Alan
    Apr 2008
    5
    Thanks Alan for the info. I do like Linux but, most of my work requires Windows software.
    Will
    Jan 2006
    20
    I have been using CamBam under windows to generate G-code. Works great and the price is right.
    http://www.brusselsprout.org/CAMBAM/
    Stan
    Apr 2007
    56
    I will second that about Cambam. Works very good for me, either alone or with an imported DXF file.
    Bill K.
    May 2008
    7
    I know EMC2 supports the use of image files. I have not tried it though. You have to turn it on as [FILTER], in your .ini file. Check chapter 23 in the EMC2 user manual about image-to-gcode. Well worth a try.
    "One pixel in the input image will be this many units–usually this number is much smaller than 1.0. For instance, to mill a 2.5x2.5-inch object from a 400x400 image file, use a pixel size of .00625, because 2.5 / 400 = .00625."
    Apr 2008
    5
    Thanks for all the replies and help. I have been using cambam to generate the gcode and it works great. Still learning but, have come a long way. I still have not figured out how to cut a vertical curve in a stock of wood. Any ideas anyone.
  1. MSC Milling machine drawing
    By Jim Estes in forum Uncategorised MetalWorking Machines
    Last Post: 04-17-2008, 02:50 AM
  2. Milling Machine Setup File
    By seal1966 in forum BobCad-Cam
    Last Post: 01-25-2008, 08:54 PM
  3. Is my drawing ok? *file now attached*
    By Zamm in forum Musical Instrument Design and Construction
    Last Post: 06-26-2007, 10:17 PM
  4. Drawing help
    By dwacker in forum Dolphin CAD/CAM
    Last Post: 05-08-2007, 09:53 PM
  5. Newbie question: how do I machine this? (Drawing attached)
    By Aegeon in forum MetalWork Discussion
    Last Post: 12-04-2005, 08:20 PM
