603,326 active members*
3,194 visitors online*
    Feb 2004
    2337
    Mach2 & Rutex relay board.
    Up till now I have been turning my spindle on and off manually.
    I havent connected the spindle to the Rutex relay board yet.
    I have tried to get the relays to respond to Mach2 input but cant hear them click in or out. I have tried to configure the relay board to respond to Mach2's input but have had not luck.
    In the Rutex pdf concerning the relay board it says that I need to use pin 14 of the printer cable and use port C./1 . What does C./1 mean.
    Has any one else successfully enabled spindle control using the relay board?
    Being outside the square !!!
    Mar 2004
    1661
    Not yet, I have my board somewhere on the way to Sweden right now...
    There is a document describing the schematic at the rutex web page, at http://www.rutex.com/pdf/R990IO.pdf where you hopefully can find the answer. Any possibilty that some shortcut jumper is left somewhere after tuning the drives that maybe takes over a parallel port pin?
    Cheers,
    Sven
  1. Mill Post: MC9 to Mach2...I'm using a Xylotex Board?
    By EPM in forum Screen Layouts, Post Processors & Misc
    Last Post: 04-21-2005, 03:05 AM
  2. Mach2 configuration for Rutex R90H
    By Left in forum Mach Software (ArtSoft software)
    Last Post: 01-20-2005, 10:24 PM
  3. E-Stop Hard Wire and to Software?
    By Sanghera in forum CNC Machine Related Electronics
    Last Post: 10-30-2004, 05:22 AM
  4. Gecko vs Rutex
    By samualt in forum Gecko Drives
    Last Post: 10-21-2004, 07:48 AM
  5. Mach2 and Rutex
    By ynneb in forum Mach Software (ArtSoft software)
    Last Post: 03-31-2004, 09:37 PM
