586,096 active members*
3,756 visitors online*
IndustryArena Forum > CAM Software > EdgeCam > Drilling cycles
    Sep 2006
    136
    Drilling cycles
    I'm back to doing some milling in edgecam, and it's been a while and i'm rusty.
    I'm stuck with my drilling cycle:
    G81 G98 R5.0 Z-5.5 F75.0
    I want the G98 to be a G99 (governing whether the retract height is to the R plane or to the initial plane).
    There's a setting somewhere in the drill dialogue box to choose, but can I find it? Nope.
    Anyone?
    J
    Jun 2003
    73
    All you have to do is put a value in the retract filed and it will output a G98. If it's left blank then you get a G99
    Mike W.
    Apr 2008
    6
    Hi
    In the depth tab in the drilling dialog box make the figures in the level & retract equal to the clearance figure and you will get a G99, if the combined figures of the level & retract are less than the clearance you will get a G98.
    Hope this is helpful.
    May 2004
    142
    THIS IS WHAT SHOULD BE IN THE APPROPRIATE CODE CONSTRUCTOR BOX
    [DELETE][BLKNUM][PECKGCODE][XMOVE][YMOVE][ZDEPTH][PECKDEPTH][RPLANE][CYCLEZFEED][RETRACTGCODE]
    WHICH YEILDS THE CODE....
    N6 G73 Z-?.?? Q0.? R0.1 P0.5 F?.?? G98
    DONT MIND MY SPELLING ... IM JUST A MASHINIST
    Sep 2006
    136
    Ah ha! That's the one. And people say Edgecam is unintuitive..pah. :tired:
    ta!
    Quote Originally Posted by JS TRIDAN View Post
    Hi
  1. different peck cycles?
    By C5turbo in forum Fanuc
    Last Post: 11-06-2008, 12:03 PM
  2. G85 for Boring Cycles?
    By stuby in forum G-Code Programing
    Last Post: 01-23-2008, 08:04 AM
  3. canned cycles on 16t?
    By DocHod in forum Fanuc
    Last Post: 07-09-2007, 01:58 AM
  4. G90/G91 in canned cycles
    By alfalfa in forum CamSoft Products
    Last Post: 02-25-2007, 12:20 PM
  5. drilling and drilling cycles tutorial
    By wmorre in forum MetalWork Discussion
    Last Post: 10-19-2006, 12:30 AM
