587,568 active members*
3,480 visitors online*
    Feb 2008
    7
    Tool Breaking! Any Suggestions?
    I have beenn cutting shapes(on Mill table) out of 3/4" plywood with a 1/8"X3X1" (GARR TOOL)bit for over a year now. Recently, the bits are breaking(sometimes on contact, sometimes after a short run. I am using 2-passes at 3/8" ea. Which is halfway through. My FeedRate is F30, my PlungeRate is F30.
    Never had this issue before. If anyone has any suggestions/solutions, please feel free!
    Thanx for your help!
    Are they breaking in the middle of a cut? Or at the end of a cut?
    Dec 2006
    242
    Are you using the very same part number endmill? A difference in the helix angle or number of flutes, etc could be it if your tool part number is different. how is the runout on your spindle? Same rpm's? lowering the rpms actually gives you a higher chipload with G94.
  1. multicam 3000 tool holder breaking continuously
    By schantal in forum Commercial CNC Wood Routers
    Last Post: 10-19-2008, 05:33 PM
  2. Tool Breaking! Any Suggestions?
    By SmoothOperator in forum Wood Lathes / Mills
    Last Post: 05-26-2008, 03:24 AM
  3. Tool Room Mill Suggestions Please
    By usmc2033 in forum Haas Mills
    Last Post: 04-24-2008, 04:48 AM
  4. Cutting Tool Suggestions
    By Jonathan3520 in forum Uncategorised MetalWorking Machines
    Last Post: 11-15-2006, 05:56 AM
  5. Cutting Tool Suggestions
    By Jonathan3520 in forum Shopmaster/Shoptask
    Last Post: 11-10-2006, 06:28 PM
