603,365 active members*
2,991 visitors online*
    May 2008
    Question Biesseworks programing
    using Biesseworks on a Rover B 7.40
    I would like to speed up the program work time,
    EXAMPLE:
    Simply, if you run a bit down a 10ft board using 3 passes, it starts at one end rips down to the other end, lifts up, comes all the way back to the start point, lowers for pass #2, rips back down to the end, and repeats(pass#3).
    Is there a way for it to run the first pass lower at the end and come back instead of going always from the start point.
    it seems like just a time waste when we all know time=money,money money
    thanks.
    Jul 2008
    34
    What i do is to create three individual programs of the same geometry and simply reverse the second ones direction opposite to the first and third.
    You must first create the program and when you see the different programs on the left hand box dubble click the relavent sub program and check the reverse box, if you do not see it there then go to settings, milling data and look for the reverse possible box within the typical data field.
    hope this helps
    jeremy
  1. Heidenhain programing help
    By lazerracing in forum Bridgeport / Hardinge Mills
    Last Post: 01-07-2016, 09:15 PM
  2. Help with Biesseworks
    By als12 in forum Commercial CNC Wood Routers
    Last Post: 03-17-2015, 12:12 PM
  3. 0-M programing help please
    By venomgrrrl in forum Fanuc
    Last Post: 12-08-2007, 06:51 AM
  4. CNC programing
    By Fryzss in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 10-27-2007, 04:33 PM
  5. CAM programing
    By kenlambert in forum G-Code Programing
    Last Post: 02-03-2006, 07:03 AM
