603,890 active members*
2,900 visitors online*
    Nov 2007
    12
    Tornos Enc-264 programing help
    Hello,
    I am having a hard time getting my tornos to run. In the sample programs in the manual there are two sub routine's that i am unsure what they do they are or of I have to have them in my program.
    G160 H9810
    G160 H9910
    They seem to be in every sample progarm for channel 1. I am new to cnc let alone swiss. I also have some alarms that pop up. They are
    -2035 p/s clamping oil ( I filled it and the alarm went away for a little bit but came back, do I just need to fill it again?)
    -008 p/s this one is not in my manual so I don't what this is.
    -945 This says it is a servo alarm, But when I check the read outs on them the are dashes as the sould be.
    Please help me as I bought this machine to run a job and ended up doing it manually.
    Thanks in advance, Colin
    Jun 2015
    4
    Re: Tornos Enc-264 programing help
    Hello! I've got some issues with my ENC-264. The most problematic one, at the begining of the program, when the cutoff tool makes a clear cut, the main head supposed to go back, with open collet (In Z direction). But instead it goes right towards the tools (with open collet), and an error code arise (It's in end position -Z), so i can not produce anything. Does anyone have idea, how to get it back to work?
    Header Looks as:
    G161 A16.0 B0.03 C0202 F-92.0 h3.0 I0 K1 J1 M40 Q0 R50 S600 T1800
    Thanks.
    Jul 2018
    Quote Originally Posted by EvansMachine View Post
    Hello,
    G160 H9810
    G160 H9910
    Do you still have enc 264? I have solution for your one problem. 008 and 2035 alarm
  1. Tornos ENC HELP!!
    By EvansMachine in forum CNC Swiss Screw Machines
    Last Post: 09-08-2015, 01:38 PM
  2. Online cnc programing/ offline cnc programing
    By grimantas in forum Polls
    Last Post: 11-28-2012, 02:03 PM
  3. Tornos TB DecoEvo 10
    By mikeswiss in forum CNC Swiss Screw Machines
    Last Post: 10-23-2012, 05:30 PM
  4. Tornos ENC 162
    By Beep2Beep in forum CNC Swiss Screw Machines
    Last Post: 11-17-2011, 03:44 AM
  5. Programing Tornos ENC 167 , 163
    By dali_290 in forum CNC Swiss Screw Machines
    Last Post: 11-12-2010, 11:44 PM
