603,793 active members*
4,393 visitors online*
Page 1 of 2 12
Results 1 to 20 of 30
    Manual Pulse Generator
    The construction of my new Super-V router is nearly finished, and I have started working on the electronics. So far I have everything required, including a new Manual Pulse Generator. Here is a list of the main components I'll be using:
    65VDC 6A power supply.
    Four Gecko G202 stepper drivers.
    Bob Campbell's Breakout Board Plus.
    Manual Pulse Generator, model ESM80.2.100.12.R.R
    Now I have wired one other router in the past, so I feel confident that I can hook this one up without too much difficulty. The problem I'm having is the lack of information as to the correct application of the Manual Pulse Generator to the breakout board.
    I have contacted Bob Campbell, and he said the Manual Pulse Generator is compatible. He also said he would look for a document which explains how to add it to the breakout board. Unfortunately he has not responded. Now I'm in need of this information, so I can design the console which will have all the controls and switches for the router.
    If anyone has any information as to the proper procedure and wiring, it will be greatly appreciated!
    Widgit
    Feb 2007
    4550
    LMS MPG
    This document gives basic wiring not directly applicable to the Campbell product however it may help you.
    Attached Files Attached Files
    Aug 2005
    1622
    I've been kind of pondering how this was done in Mach, me-self; on the CNC4PC board.
    The pendant I have is a Euchner with MPG, Estop and a few optional function buttons. The back burner was imagining what inputs would be required with a second port to utilize.
    Thanks much for the thread and good info to match it.
    DC
    Thanks for the replies!
    Now I just realized I've been looking at the older .PDF file rev 1.7 of my breakout board, as I have a rev 1.8 board.
    The rev 1.8 file indicates that the 6-pin jumper J23 is for Encoder, and the silkscreen on the board says MPG.
    J23
    Pin1 Isolated GND
    Pin2 Isolated gnd
    Pin3 Isolated to pin 12 of parallel port (in1)
    Pin4 Isolated to pin 13 of parallel port (in2)
    Pin5 Isolated to pin 15 of parallel port (switch)
    Pin6 Isolated +5v
    One the back of the MPG, there are four screw terminals:
    1 5v/12v
    2 0v
    3 A
    4 B
    If I read the .PDF from MyLittleMachineShop.com correctly, all I need to do is connect the following pins:
    Pin6 -> 5c/12v
    Pin1 -> 0v
    Pin3 -> A
    Pin4 -> B
    However it is unclear that 0v = GNG so I still need someone like Marris to validate my conclusion!
    After this is wired in, it looks like my MACH3 software is the only way to use it, and to designate which axis to jog. This is a little confusing as well, as I have seen many a CNC console with an Axis selector switch or dial to choose which axis to move!
    Thanks again,
    Widgit
    www.widgitmaster.com
    It's not what you take away, it's what you are left with that counts!
    Aug 2005
    1622
    Can't tell you what GNG is, but I am confident GND should be 0v.
    An MPG is an encoder with detents for operator feedback, used manually to produce a pulse stream. Pins with 0 and 5v power up the devices and outputs are A&B from the MPG.
    You hit on why I posted that MPG picture. It has a 6 position axis selector which codes through 3 pin outputs used in a binary format. If you needed 6 selections you would need 3 bits to represent that to 3 inputs to a control. Since most of us are going with 4 axis max, this could be represented via 2 bits or pin inputs for 4 binary state changes. I was hoping to use the optional function buttons as X1, X10, X100 or Jog high and low speed.
    I doubt there is enough inputs to take full advantage of all these functions individually. My thoughts were, in an effort to reduce the amount of pins required for extra conveniences.
    Like in a 2 button jog function that re-uses the MPG inputs. One button could disconnect the MPG output signals and another set of buttons could send out a pulse stream on those A&B lines to function as a jog with variable frequency.
    DC
    Feb 2007
    4550
    Controling Axis with MPG
    Wigitmaster,
    A rotary switch or several momentary switches will control the selected axis.
    A Second Parallel Port Will Be Required To Address All The Triggers.
    The OEM Triggers need to be toggled.
    OEM Trig #1
    Select Axis X
    OEM Trig #2
    Select Axis Y
    OEM Trig #3
    Select Axis Z
    OEM Trig #4
    Select Axis 4
    The ones below are for speed selection
    OEM Trig #5
    X1
    OEM Trig #6
    X10
    OEM Trig #7
    X100
    You are correct zero (0) is ground.
    Jeff...
    Quote Originally Posted by One of Many View Post
    DC
    Oops!
    Actually GNG was a (fat finger) typo, something my arthritic hands do alot!
    Quote Originally Posted by jalessi View Post
    Wigitmaster,
    Jeff...
    Before I add a rotary switch to my list, is this selection process actually done in MACH3 ? There are several screen shots that indicate settings for an MPG in MACH3
    Widgit
    Feb 2007
    4550
    MPG Speed And Axis Selection
    Wigitmaster,
    MPG Speed and Axis Selection can always be controlled from within Mach.
    The addition of physical switches will give you external (remote control) options as well.
    Jeff...
    Aug 2005
    1622
    Jeff,
    So, I take it that the Pendant function takes up 7 pins for selections and 2 for pulses?
    DC
    Feb 2007
    4550
    Pins
    DC,
    Seven pins to select each trigger,
    +5 volts to trigger them high
    Two pulse connections
    One ground connection
    Some BOB's get pulled down so then trigger would go low or ground instead.
    Jeff...
    Aug 2005
    1622
    I am surpized the software doesn't take advantage of binary mode selection format to reduce the number of pins required. Leaving some for "other functions". 2 for pulses, 2 for axis, and 2 for speed.... sounds better than 9 dedicated.
    DC
    Thanks for all the replies
    As soon as I get a chance, I will do a mock run to see how it responds!
    Having an external MPG on my new machine is going to give it a touch of professionalism which I like
    Thanks again,
    Widgit
    Feb 2007
    4550
    Wigitmaster,
    Please note if you plan on using mechanical limit, home switches and the external MPG selection switches an additional Parallel Port will be required.
    Jeff...
    Feb 2007
    4550
    Please DC That would be to simple
    Aug 2005
    1622
    Quote Originally Posted by widgitmaster View Post
    Oops!
    I figured it was something like that. Gotta give you a little ribbing once in a while.
    One other function I had considered would be handy as the MPG function was a stylus format to create the old tracer mills to copy a part, rather than program it without need for geometry. Might not be worth it, but the concept sounded appealing.
    DC
    May 2005
    925
    Wigitmaster,
    OEM Trig #1
    Select Axis X
    OEM Trig #2
    Select Axis Y
    OEM Trig #3
    Select Axis Z
    OEM Trig #4
    Select Axis 4
    OEM Trig #5
    X1
    OEM Trig #6
    X10
    OEM Trig #7
    X100
    Jeff...
    Hi Jeff, maybe its a silly question, but how do you configure Mach3 to follow the OEM triggers? does one need to edit the mach screen to accomplish this? Thanks!
    Feb 2007
    4550
    Smile OEM Triggers
    Pablo,
    Yes you would type in the correct Pin - Port and enable the Triggers you want by changing the Red X to a Green Check mark.
    If you are using a second LPT Port select the corresponding Port number either Port 2 or Port 3, your original LPT Port should be Port 1
    Depending on the breakout board you have, Active Low may need to be changed also.
    Jeff...
    May 2005
    925
    Hi Jeff, thanks for the prompt reply.
    I do understand how to enable each pin, my question is how to make these oem triggers do certain function, for example:
    I see that oem#6 is triggered that should set the feed rate (x10) at a certain midrange value, lets say 10% for this example (I would use 30%)
    then I see oem#2 triggered, this means Y axis is about to be moved
    And then I move the MPG Clockwise, meaning I want to move the Y axis at the current set feed rate (x10) to a bigger Y position.
    How do I configure mach3?
    Also in your oem trigger list I would add a new one to enable/disable the pendant
    Thanks again!
    Feb 2007
    4550
    Configure Oem Trigger Codes For Hotkeys
    Pablo,
    You can assign almost any task to a Hotkey.
    The OEM Codes are used by assigning a OEM Code to a Hotkey
    See screenshot of "System Hotkeys" Setup screen
    See attached PDF for OEM Button Codes
    Hope this helps.
    Jeff...
Page 1 of 2 12
  1. Manual Pulse Generator for K2CNC
    By Mike Stevenson in forum K2CNC
    Last Post: 09-03-2009, 09:23 PM
  2. Adding a manual pulse generator to my home CNC
    By glentner in forum CNC Machine Related Electronics
    Last Post: 10-01-2007, 03:30 PM
  3. Pulse generator / controller boards for EMC.. which one?
    By ewest in forum LinuxCNC (formerly EMC2)
    Last Post: 04-23-2007, 11:53 PM
  4. USB Pulse Generator support in EMC???
    By acondit in forum LinuxCNC (formerly EMC2)
    Last Post: 01-16-2007, 01:42 AM
  5. Manual Pulse generator?
    By phantomcow2 in forum CNC Machine Related Electronics
    Last Post: 07-24-2006, 04:10 AM
