587,997 active members*
1,873 visitors online*
IndustryArena Forum > WoodWorking Machines > CNC Machining Centers > programming bolt hole pattern
    May 2008
    Question programming bolt hole pattern
    Does anyone know if its possible to program a bolt hole pattern by using angles instead of point to point without having a G68 (for coordinate system rotation) command a controller? All I want to do is change the radius of the bolt hole pattern but when I do that I have to go to a cad system to get my coordinates. A cam system won't work because we would like to change this at the machine.
    Feb 2006
    992
    Yes you can but that is option G74/G75, on other hand you can trig it out.....
    The best way to learn is trial error.
  1. Circle With Bolt hole Pattern
    By JJsFab in forum Torchmate
    Last Post: 09-01-2013, 06:07 PM
  2. Bolt hole pattern with only a drill press
    By sanddrag in forum MetalWork Discussion
    Last Post: 05-04-2006, 07:41 PM
  3. Lining up a CNC mill to an existing bolt pattern?
    By youngfg in forum MetalWork Discussion
    Last Post: 11-07-2005, 09:05 PM
  4. 200oz in Motor Bolt Pattern
    By jhwatts in forum Hobbycnc (Products)
    Last Post: 10-13-2005, 03:40 PM
