588,156 active members*
4,591 visitors online*
Thread: End result
Results 1 to 7 of 7
    Apr 2003
    1873
    End result
    Unfortionattly being quite ignorant on CNC I am not sure many times how to even frame the question I am thinking. I am wonderng when creating a drawing does OneCnc create the Gcode based on the end result or the steps it took to draw it?
    If that makes any sense at all.
    Ken
    4826
    Hi Ken,
    On the basis that you can create gcode from a customer model that was converted to igs and then opened in Onecnc, I would imagine that all traces of "drawing sequence" would be totally obliterated.
    What have you observed?
    Apr 2003
    1873
    Hi Hu,
    At the present I do not even have a CNC mill so I do not have any observations to draw experience from. When drawing a part I know that I sometimes go the long way around to accomplish the end result, my concern is, will these extra steps create problems when wanting to machine it?
    Thanks for the input
    Ken
    927
    End results
    Ken and Hu,
    The program saves the drawing steps to a temp file. That's why you can undo or redo any and all steps you make.
    Then when you generate tool paths it saves those steps also to a temp file attached to the cad file. That's why you can Edit operations,IE; tool paths, or reorder them. That's also why when you reopen the file the nc operations are still there.
    Then when you post the operations it takes those operations you have selected and turns them into code to reflect your config.
    That said, it only uses the operations that you have generated and selected to give you machine code. So no Ken it dosn't use the unselected steps you took to make your final model.
    Hu the steps are not really " totally obliterated". Just "irrelevant" as far as the machine code is concerned.
    Clear as Mud.
    Apr 2003
    1873
    Thanks to you guys the mud is now just quite murky.
    Ken
    927
    Just the way we like it.
    May 2003
    130
    drawing sequence
    It doesn't seem to matter. I complete my drawing and then tell it how to machine it.You determine drill here then here then pocket this then profile that and so on and so on.The order in which you draw it makes no matter unless you draw a line then say machine it and then draw another line and say machine that and so on.
  1. Ballscrew Basics
    By Swede in forum Linear and Rotary Motion
    Last Post: 04-05-2024, 08:10 AM
  2. G-Code to DXF
    By WayneHill in forum OpenSource Software
    Last Post: 05-19-2021, 11:26 PM
  3. Visual Basic Controller Project
    By dwwright in forum Visual Basic
    Last Post: 04-16-2016, 10:31 AM
  4. Cutting bit questions
    By cncadmin in forum Uncategorised MetalWorking Machines
    Last Post: 02-20-2004, 10:12 PM
