588,703 active members*
7,846 visitors online*
IndustryArena Forum > Mechanical Engineering > Linear and Rotary Motion > Best belt drive ever! (If I do say so myself)
Page 1 of 19 12311
Results 1 to 20 of 370
    Hi guys,
    I'm not ready for a full release of this, so I'm starting a thread here for discussion. This summer, I'll put a complete product release thread up in the proper place.
    This is called ServoBelt. The vid is (almost) self explanitory.
    http://www.bell-everman.com/ServoBelt.wmv
    It's been tough keeping my mouth shut about it when asked what's the best way to drive a large format DIY NC machine!
    Now I can talk about it, as it is patent pending as of Tuesday.
    I plan to have parts available online in the fall for people here, though our usual business is OEM customers. It would be a new realm indeed for us to sell parts and not whole systems, but since joining this forum, I have a desire to help!
    Enjoy.
    Jun 2007
    41
    Your link still doesn't work.
    Quote Originally Posted by zenbot View Post
    Yeah. Weird.
    OK, I changed the name. If you paste what's in quotes in your browser, it should go.
    Am I daft, here? I'm using the link icon and typing it in, and it shows right, but does not work. hmmm
    I fixed it the first time, but you're renamed version doesn't work. You don't need to use the link icon, just type in the address. Also, you had a backslash instead of a forward slash, but that didn't fix it.
    Thanks, and sorry. I wondered why my experiments to make it work were changing!
    Seems to be case sensitive(?)
    Feb 2004
    1086
    Mike,
    Looks like a really interesting system. Does it use other Bosch parts like the linear rail and blocks, belts, or rack? Any target pricing for, say, an 8.5 foot section of servobelt?
    Ahren
    www.cncrouterparts.com
    Quote Originally Posted by ahren View Post
    Mike,
    It will mount to two t-slots on either Bosch or 80-20 45mm series extrusions. We have a version that wraps around so mounting is to two adjacent slots at 90 deg. Bearing rails are currently 20mm Rexroth-Star, standard is the E-line from them, which is an aluminum rail with steel inserts, and aluminum bearing blocks with inserts as well.
    The belt carrier is our own extrusion, and has features to hold limit sensors (the Bimba pneumatic cylinder sensors).
    We're not quite in production yet and still building our test portfolio. Pricing is forthcoming.
    Higher res video of ServoBelt on youtube
    [ame="http://www.youtube.com/watch?v=OdJoVh6DRPA"]YouTube - ServoBelt: amazing belt drive[/ame]
    May 2007
    72
    I like it, I had considered a belt assembly using just a tight tough belt stretched from end to end but most of the belting I looked at didn't like being bent backwards. Being I am not an engineer by trade, What kind of belt sizing would I have to use for a roughly 250 lb gantry attempting to achieve 875 imp. I don't know how fast I can accelerate it being I only have servo motors capable of 900 oz. I am using dual x axis drives. Hoping it will work well. I did a little home work and this is what I came up with for motors. I would like to purchase 2 of these units with 8.5' travel. Is that something that could be at a reasonable request and of couse HOW much will I have to shell out?
    May 2006
    1469
    Interesting concept Mike. Looks good.
    At first I thought you had only one roller each side to keep the belt engaged with the rack but then I see you have two rollers each side.
    Is the rack something you have manufactured to match the belt pitch or is it another length of belt with teeth up?
    Greg
    Quote Originally Posted by Bobbyr70 View Post
    ....What kind of belt sizing would I have to use for a roughly 250 lb gantry attempting to achieve 875 imp. I don't know how fast I can accelerate it being I only have servo motors capable of 900 oz. I am using dual x axis drives. ...
    I do engineer these things, but still like to think in simple terms. Just pulling it out of the air, check how wide you can get 5mm pitch belting. (from SDP(?))
    So you have 900 in-oz, that's 56.25 in-lb. Let's say you use a 1" pinion, the radius is .5". So 56.25/.5 is the linear force you can deliver, 112.5 lb. Each motor will see 125 lb of force per g. You are capable of almost a g with a one inch pinion! 1g is 32.2 ft/sec/sec, so I'll leave the last math to you, but acceleration will not be your problem. What you will deal with is stiffness of the drive line, and that's where ServoBelt will excel. There's no stretchy belt in the stiffness equation.
    ....I would like to purchase 2 of these units with 8.5' travel. Is that something that could be at a reasonable request and of couse HOW much will I have to shell out?
    I don't know yet. We're making them for a few early adopter OEM's. The belt carrier is going to be an extrusion, but is now a rather expensive long machined part. I'll be selling this extrusion, belting and all other parts. I expect for folks around here it will be in kit form, but who knows. You can do this entirely yourself, though. Just know that you need flanges on the pinion if you want to run the belt on something flat. (we capture both sides of the belt stack so no flanges are needed anywhere in the drive unit.)
    Quote Originally Posted by Greolt View Post
    Greg
    Same belt bonded with teeth up. You need to use the "T" series, in the case of the NEMA23, it's T2.5 or T5, NEMA34 is T5. T belts mesh with themselves, while AT does not. The Gates power grip works, but is a rounded profile.
    May 2007
    72
    Thaank you so much for the information, I was hoping someone could explain it that easy, I appreciate you time and effort. Will keep in touch and see what unfolds as the project progresses. I would devote full time to it if only my real job was not in the way. And there are all the honey do's and boy does she have a list.....
    Jul 2007
    1602
    This system could also be used as the foundation for a pretty sweet anti-racking drive system for gantries.
    In its most elegant form one could drive a pair of pinions with a common shaft running through a hollow shaft servo or stepper. Other, less elegant, options would be belt-driven common shaft or two half shafts driven by a double ended motor.
    Quote Originally Posted by rowbare View Post
    Yes, all that is possible, as well as multiple motors to drive a single load, and multiple independent axes on the same belt...
    Apr 2008
    384
    This is an awesome system Mike, good job.
    I noticed that you mentioned that you may be supplying parts, I hope you don't forget us international buyers.
    Oct 2006
    669
    just wanted to stay in touch with this thread
    just poking my head in Looks like a really cool product, I'm already thinking of a few uses for it
    Quote Originally Posted by yngndrw View Post
    Thank you! And, I will attempt to forget no one!
    ServoBelt cantelevered robot
    Just thought I'd post up one I'm working on that has a 20x20" travel. I'm trying to come up with an inexpensive screw type Z to go on this... maybe a roller screw! ha
Page 1 of 19 12311
  1. Belt drive or direct drive?
    By VegasRhino in forum Drilling- and Milling Machines
    Last Post: 10-10-2013, 12:12 PM
  2. Direct Drive Vs Belt Drive for a Mill/Drill Retrofit?
    By pfeist in forum Uncategorised MetalWorking Machines
    Last Post: 02-13-2012, 09:12 AM
  3. X2 belt drive
    By eartaker in forum Benchtop Machines
    Last Post: 07-07-2010, 08:26 PM
  4. Belt drive or direct drive?
    By rholliday in forum Uncategorised MetalWorking Machines
    Last Post: 02-17-2009, 12:21 AM
  5. Need Sherline Belt & qestion on X2 Belt Drive?
    By Oldboy in forum Benchtop Machines
    Last Post: 03-06-2008, 07:42 AM
