603,936 active members*
2,174 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > How do I create solids from lines?
    Sep 2004
    30
    here's a screenie:
    but, as u can see, the block isn?t totally solid..only the rectangular cubes are what do I need to do to make it just one block? (for the columns, I used the already made solids that bobcad-cam offers)
    Nov 2003
    49
    Solids are planar surfaces that have been stitched together.
    1, select the lines that form a square or a rectangle. The arrow direction on each line must be head to tail.
    2, execute the SOLIDS/SURFACE CREATION/PLANAR SURFACE command with the distance = 0.
    3, repeat steps 1 and 2 until all the surfaces have been created.
    4, select all the surfaces and execute the SOLIDS/STITCHING/STICH SURFACES TO SOLID.
    Poor planning on your part does NOT constitute an emergency on my part!
    Sep 2004
    30
    thx so much!
  1. single line fonts?
    By balsaman in forum Uncategorised CAM Discussion
    Last Post: 02-18-2006, 06:51 PM
  2. Can't see lines
    By Mr.Chips in forum Uncategorised CAM Discussion
    Last Post: 04-03-2005, 04:29 PM
  3. Dirction / Step lines!
    By bigal in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 02-06-2005, 08:51 PM
  4. Converting solids, and surfaces
    By MILLMANM in forum Mastercam
    Last Post: 01-05-2005, 06:31 PM
