586,108 active members*
3,052 visitors online*
IndustryArena Forum > MetalWorking Machines > OKK > OKK Milcon III with MELDAS 83A
Results 1 to 16 of 16
    Apr 2008
    136
    I just bought an old machine with totally dead condition. But the controller inside the panel still looks good (so far looks original). Before I decided to retrofit, I'd like to make sure that machine still can be repaired. But I have problem, because the battery has lost.
    Does anyone have paramater description for MELDAS 83A?
    Feb 2008
    6
    meldas 83.....
    hy,
    i have an okk mcv-300 with meldas 84.
    i think it is the same controler.
    send-me an e-mail i
    i will send you my parameter (from my working machine...).
    regards
    den.
    Dec 2007
    8
    Do any1 of u guy have manual for Mitsubishi Dc servo TRA6oC ?
    Apr 2008
    136
    Quote Originally Posted by mosesooi View Post
    Have you try meau.com? I got it from there, but I can't find for MELDAS 83A manual.
    btw, what is your controller? is it MELDAS 83A? do you have copy of parameter list?
    Dec 2007
    8
    Yes the controller is Meldas 83A,With all Parameters in.Controller out,Tra60 Drive Manual
    needed so that i can change to other Controller.May Be other brand!.Don't too hopeful
    to meau.com,they care about New Products only!!!
    Apr 2008
    136
    Have you check it on meau carefully?????
    http://www.meau.com/Files/BNP-A6478.PDF <== TRA30 & TRA60
    Now, whats a problem with your controller?? I can't find a way how to write parameter on it. Seems to locked by keyword or jumper setting on MELDAS 83A. Any clues?
    Dec 2007
    8
    parametric,
    The Password Is PS In First Line.
    Dec 2007
    8
    parametric,
    thanks for your reply,but fail to connect the site.Should I register first? Where & How??
    Apr 2008
    136
    check your PM
    Apr 2008
    136
    Find the filename that I give on the site
    Jan 2008
    5
    OKK MCV 300
    Is there anyone available that currently has manuals to a meldas 84 control?
    Dec 2007
    8
    parametric.ms.
    Hi Andre,
    Okk Is A Good Machines But Not Meldas 83A!
    I Don't Think You Can Run M99 In Your Machine.
    All Limited M Code And G Code Is Stated In The Side Of The Main Panel.(Which Contains
    The Meldas 83A ).Please Keep In Mind, Your MC Is An NC Not CNC!!!
    Any How I Will Give You All The ParameterS You Need:
    S1 +0 +120
    0 120
    0 160
    0 0
    1 8000
    0 8000
    70 6000
    100 0
    CF +4000 +2
    4000 2
    4000 2
    0 0
    20 0
    20 0
    7 0
    0 0
    BR +4 +6400
    5 6400
    0 4800
    0 0
    0 0
    0 0
    0 0
    0 0
    T1 +5 +7
    5 3
    10 10
    3 30
    3 60
    3 5
    7 20
    7 7
    D1 +0 +2308
    0 2308
    0 2504
    0 0
    0 11
    0 10
    0 8
    0 0
    P1 -8901 -601
    8601 401
    8401 1011
    7601 3950
    6601 3850
    2601 3451
    1601 3051
    901 2251
    P17 -1951 -2251
    1851 1851
    1701 1450
    7511 650
    6511 250
    4251 +0
    3850 +0
    3451 +0
    FX1 +0 -921000
    0 -401000
    1000 -471000
    1000 +0
    300 0
    300 0
    300 0
    0 0
    Apr 2008
    136
    Thanks a lot for replying my message.
    But I still don't get it how to make a rewind program in okk
    My control contain with this :
    1. Circular Interpolation
    2. Radius Programming on Arc
    3. Simultanous 3 Axis Linear Interpolation
    4. Return to Zero
    5. High Speed Return to Zero
    6. Mechanical Handle
    7. Rapid Traverse Override
    8. Stroke Check
    9. Additional Tool Offset 32 Set
    10. Cutter Radius Offset
    11. Canned Cycle
    12. Memory Type Pitch Error Compensation
    13. Auto Restart
    14. Decimal Point Program
    15. Program Number Search
    16. Tape Store 10m Edit
    17. Sub Program Function
    18. External Operation Board
    19. Built in Sequencer
    20. Built in Machine Operation Panel
    21. Xxxxx (kanji fonts)
    22. Tape Punch / Print Out I/F
    I have no idea how to activate the option parameter. Should I try one by one with hexadecimal configuration?
    How about yours? Is it same optional with mine?
    Sorry if I disturb you recently.
    Regards,
    Andre
    May 2005
    109
    parametric.ms.
    Hi Andre,
    S1 +0 +120
    0 120
    0 160
    0 0
    1 8000
    0 8000
    70 6000
    100 0
    CF +4000 +2
    4000 2
    4000 2
    0 0
    20 0
    20 0
    7 0
    0 0
    BR +4 +6400
    5 6400
    0 4800
    0 0
    0 0
    0 0
    0 0
    0 0
    T1 +5 +7
    5 3
    10 10
    3 30
    3 60
    3 5
    7 20
    7 7
    D1 +0 +2308
    0 2308
    0 2504
    0 0
    0 11
    0 10
    0 8
    0 0
    P1 -8901 -601
    8601 401
    8401 1011
    7601 3950
    6601 3850
    2601 3451
    1601 3051
    901 2251
    P17 -1951 -2251
    1851 1851
    1701 1450
    7511 650
    6511 250
    4251 +0
    3850 +0
    3451 +0
    FX1 +0 -921000
    0 -401000
    1000 -471000
    1000 +0
    300 0
    300 0
    300 0
    0 0
    Hi Mosesooi,
    Could you please PM me the 83A parameter setting procedure (and parameter list if possible)? My OKK have lost all parameter because battery was empty.
    Thanks a lot.
    Jun 2017
    Re: OKK Milcon III with MELDAS 83A
    I have two machine of OKK Millcon III (MHA 400 & MHA 300). Both has Meldas 83A controller
    The machine when bought was not in running condition and was idle for a while
    I tried to power up the machinery
    Both displays the same alarm E=20 when i try to power on the machine and release the emergency
    Moreover I tried to change the parameter which wasn't successful at all
    I have been told that it's a software related emergency parameter
    I'm not convinced with the reply
    I'm open to suggestions
    If needed I can send screenshots
    P.S. I have the original parameters. But i would like to know the parameter setting procedure. Because however we do it, we couldn't change the parameters other than the M list
    Kindly assist
    Jun 2017
    Re: meldas 83.....
    Kindly assist
  1. Meldas 60
    By agu in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 09-18-2012, 11:13 PM
  2. For MELDAS 300 PLC
    By yepingapple in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 10-21-2009, 02:32 PM
  3. MELDAS 83A
    By parametric.ms in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 06-20-2008, 07:50 PM
  4. Meldas-m60
    By CHANDRU in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 04-17-2008, 02:44 PM
  5. meldas 500
    By positiverake1 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 08-14-2007, 02:27 AM
