587,482 active members*
3,482 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > Removing steel with corncob rougher?
    May 2007
    327
    I have IH mill 3 hp, with 3250 rpm, and flood coolant; need a good tool to hog out some mild steel flat 4 flute HSS endmill still very slow. Is there a better tool 6 flute?, high helix?, how about using a rougher? thanks
    Apr 2007
    64
    What size roughing endmill?
    Are you slotting or profiling?
    Coated or uncoated?
    6 flute Roughers are usually larger the 1 inch.
    Make sure you get fine pitch not the coarse.
    They cut better.
    Mar 2004
    1543
    A rougher is a good choice.
    If you'd like to go to a whole nuther level, take a look at Sandvik R390 insert cutters. I normally run them dry, thermal shock is huge issue. They are designed to put the heat in the chip - they come off black and will burn you if you get in the way.
    Karl
    May 2006
    196
    Why don't you give a carbide fine tooth rougher a try? You can get a 3/4 tialn coated for about $80.
  1. Removing Tooling
    By Mooser in forum Uncategorised MetalWorking Machines
    Last Post: 03-07-2008, 03:16 PM
  2. Wave cut rougher?
    By kesparate in forum Uncategorised MetalWorking Machines
    Last Post: 11-16-2007, 08:47 PM
  3. Removing a Gecko
    By sploo in forum Gecko Drives
    Last Post: 12-11-2006, 11:51 PM
  4. Removing nut off ballscrew, I've never seen anything like it
    By geohot in forum Linear and Rotary Motion
    Last Post: 12-24-2005, 04:53 AM
  5. Removing the armature ?
    By Ken_Shea in forum Servo Drives
    Last Post: 10-10-2005, 08:40 PM
