588,597 active members*
12,453 visitors online*
IndustryArena Forum > CAM Software > Mastercam > tool library for 2 machines MC9
Results 1 to 8 of 8
    May 2007
    155
    I have 2 machines each have 24 pocket SMC
    one machine does roughing and alot of billet alum
    the other machine does complex surfacing
    when programing a part it would be nice to open the tool llibrary
    for the machine that the part will be made on
    thanks for the help~kojack
    Sep 2007
    92
    I have had similar issues when I was only using MC9 and earlier, I would create a MC9 file (delete the geometry after after creating the new tools) with as many tools as I usually use and save that as (for example) "TOOLS_HAAS.MC9" and for the other machine do the same and call it (also for example) "TOOLS_MAZAK.MC9" then when you are ready to program a part for your HAAS machine, (I do not know what kind of machine you have) get the "TOOLS_HAAS.MC9" and merge it with your part file and re-save it as a working file and begin chaining geometry and you will have access to all those tools. I hope this helps, if you need further explanation, just ask
    May 2007
    155
    Quote Originally Posted by CNC_BOB View Post
    I did that .. but I cant seem to reload it when I open a new part ...
    I wish you could save the tools in the tool manager...
    most of my parts use the same tools when I need to change drill size I just
    put a diff size in the drill chuck...
    The merging part is where im scewing up ...
    hopfully I can figure it out .. My simulators have a machine tool list that saves
    thanks~Kojack
    Sep 2007
    92
    kojak,
    I checked my MC9 and it does have a tool library but as I mentioned before I found it easier to have a "fake" file that has a bunch of tools in it, open that first (that is key) then do "file merge" with the actual part you are going to machine. doing it the other way will not bring in your list of tools in the operations manager, just trying to help
    Jul 2003
    263
    toolpath - job setup - tools - right click in tool manager - get from library - find tool library - highlight tools needed - click ok.
    i do it all the time, i have different libraries for different type of materials, machines etc.
    If you can ENVISION it I can make it
    May 2007
    155
    kojak,
    Ok I see it now ...
    Thanks for all the help ...
    Apr 2003
    3578
    I just keep programming and I will have for example 10 tools thru 10 for the first machine and another 10 tools 1 thru 10 again. Mastercam will just post the tools used for those ops . This way I keep using the same file from Roughing to Finish.
    Cadcam
    Mar 2006
    1013
    You can have a different tool Lib for each machine. Copy the Tool Library and re-name it for your machine (i.e. Tools-Mazak.TL9. Just select that library when you start programming for the Mazak.
    Mike Mattera
    Tips For Manufacturing Training CD's, DVD's for Mastercam, SolidWorks, Inventor, G-Code Training & More
    http://www.tipsforcadcam.com
  1. tool library...or is it?
    By brooklynmetal in forum BobCad-Cam
    Last Post: 06-16-2008, 07:34 PM
  2. Tool Library Questions
    By Mastercam User in forum Mastercam
    Last Post: 05-11-2008, 07:22 PM
  3. MCX Tool library question
    By MauserBob in forum Mastercam
    Last Post: 04-18-2008, 02:20 PM
  4. Tool Library Catagories
    By PinMan in forum BobCad-Cam
    Last Post: 04-18-2008, 01:21 PM
  5. How to get more tools in the tool library?
    By clint_so in forum Mastercam
    Last Post: 07-24-2007, 04:55 PM
