588,147 active members*
6,087 visitors online*
IndustryArena Forum > CNC Electronics > UHU Servo Controllers > The UHU parts list, questions and improvement.
Page 1 of 3 123
Results 1 to 20 of 46
    Dec 2005
    313
    Here you can find the partslist for the UHU http://gsst.wikispaces.com/UHUget
    Questions or improvements can be discussed in this thread.
    Dec 2007
    Talking UHU Parts
    Anyone still selling parts kits for the UHU Servo Board?
    May 2006
    107
    Is it possible to use inductor PM2120-2R2M-RC insted of PM2120-1R2M-RC on UHU HP (L1,L2)?
    Aug 2006
    2758
    Quote Originally Posted by Andrey67 View Post
    No, it is almost double (2.2uH) the inductance of the right one (1.2 uH), also the saturation current is lower (19 Amps)...
    May 2006
    107
    To clarify the value of the following components C14 and C18 (tantalum or electrolytic)?
    What are jamper's (RST1 and P3) on PCB's for and if it's necessary to install (to short-circuit) them?
    Aug 2006
    2758
    For HP_UHU only: C14 and C18 could be tantalum capacitors. RST1 is a reset jumper and should be normally open (briefly closed for hardware RESET). P3 is a test point for GND potential, it is permanently shorted on the PCB by a thick copper trace. P3 serves as a test point GND for the oscilloscope, and as a auto-router trick to separate Power and Logic GND while auto-routing the PCB.
    Regards,
    Kreutz.
    Dec 2005
    231
    C21, C22, C25 and C26 and other issues
    I've finally gotten around to assembly of the first HP-UHU and have made up some sheets with colour coding for easily locating where all the parts go. Once the first board is up, I'll scan them and post to make it easier for everyone else (and me for the other 3 boards).
    There are a couple of problems though. I've downloaded several zips with component layouts. On one, the PCB is marked Rev 0.10b while the green Rev00c 08/2007 component layout doesn't match the board. Instead I've been using the monochrome Rev 1.00 12/2007. However, it's missing R46 right by J7.
    Next, the component list has C21 etc. listed as using a 5.1X3.2 footprint but in fact the caps on the board are on 0.1" spacing. What is the part # (or is there one) of the 0.22uFd MKT capacitor that fits this?
    Any chance that an up to date version of the component overlay for the PCB marked 0.10b can be posted. Then I can transfer my coloured marks and labels it it along with Digikey and Newark part #'s.
    John Dammeyer
    Aug 2006
    2758
    Quote Originally Posted by jcdammeyer View Post
    John Dammeyer
    Here is the component layout, later I will look around for the capacitor's part number.
    Regards,
    Kreutz.
    Attached Files Attached Files
    Dec 2005
    231
    Quote Originally Posted by kreutz View Post
    Regards,
    Kreutz.
    Thanks. BTW, I have installed the 2200pF caps on the differential encoder SN75115 interface. I will investigate this O error problem.
    John
    Aug 2006
    2758
    Dec 2005
    231
    So you are saying just take the 0.2" (5.08mm) spacing part and bend the leads inwards to fit into the 0.1" (2.56mm) spaced holes? Kinda figured this was a layout error. ;-)
    Curious as to why the component list has the footprint as 5mm.
    John
    Aug 2006
    2758
    John
    The component was listed as 5.08 mm on my Altium DXP2004 library but the footprint was wrong. Will be corrected on the next revision of the pcb (not scheduled yet)...
    Dec 2005
    231
    I got caught that way once with 4N33s. In that case the pins were wrong on the schematic object and so the layout was wrong. Expensive mistake.
    Here's a picture of progress so far. Just needs LEDs, ICs in sockets, 470pF, 1uFd 250V on bottom along with transistors and voltage regulator. Already the circuit boards weighs an extra 150 grams.
    Now to make a list of what parts are missing for the rest of the boards.
    Looking forward to trying it out.
    John
    Aug 2006
    2758
    John
    Looking really good so far...
    Kreutz.
    Dec 2005
    231
    Kreutz.
    Thanks. I'm only sticker inner person. You did all the work.
    BTW, I've requested a price quote from www.thermoflo.com for 6.5" lengths of their E1197 heatsink extrusions. It's 5" wide and looks like it may be perfect for the HP-UHU.
    John
    Feb 2008
    553
    Arrow Copper boards
    Quote Originally Posted by vroemm View Post
    Hi everybody !
    I just got the parts from Reichelt.de and just found that the copper boards have 35 micro meter of copper on them not the 75µm claimed in the parts list, and after verification Reichelt.de sels only 35µm copper boards what ever the kind.
    Thanks !
    cnc2.
    Aug 2006
    2758
    John
    Hello John;
    Did you get that price quote?
    Kreutz
    Dec 2005
    231
    Hello John;
    Kreutz
    Not yet. I'll follow up on Tuesday. I've been away for a few days. And work-work has gotten in the way.
    John
    Feb 2006
    63
    Re: The UHU parts list, questions and improvement.
    Hi; could someone please point me to a place were I can download the instructions to build these boards and the parts list?
    Thank you
    Mariano
    - - - Updated - - -
    Thank you
    Mariano
    Dec 2005
    231
    Quote Originally Posted by rasta View Post
    Thank you
    Mariano
    - - - Updated - - -
    Thank you
    Mariano
    I don't think the boards for the HP_UHU are available anymore. Kreutz was the designer. Likely he may have a web link to gerbers etc. for making more boards. I can email things like parts lists etc.
    - - - Updated - - -
    Thank you
    Mariano
    - - - Updated - - -
    Thank you
    Mariano
Page 1 of 3 123
  1. Replies: 10
    Last Post: 07-08-2013, 03:45 PM
  2. G0704 conversion parts list & Questions
    By TurboGt in forum Benchtop Machines
    Last Post: 03-12-2012, 11:36 PM
  3. Parts List
    By Scottjit in forum Daewoo/Doosan
    Last Post: 12-09-2009, 11:26 PM
  4. Arboga G2508 Parts, Parts List, Manual
    By omnimfg in forum Want To Buy...Need help!
    Last Post: 04-03-2009, 05:59 PM
  5. The UHU wiki, questions and improvement.
    By vroemm in forum UHU Servo Controllers
    Last Post: 08-26-2008, 03:07 PM
