603,810 active members*
2,756 visitors online*
IndustryArena Forum > CAM Software > Mastercam > MCX2 setup sheet????
Results 1 to 6 of 6
    Jun 2007
    10
    Thumbs up MCX2 setup sheet????
    I need to hand off a setup sheet with estimated operation times on it. At past jobs I have just used the VERY generic setup sheet and hand edited as needed, it's gotten the job done. But now I need the times to be near exact. When I backplot the times seem fine, however, when I create a setup sheet using the mill.set file the times are WAY different(1.5-2 X). Its a lot to hand edit and quite a pain. Are there any good setup sheets out there or is the generic mill.set just in need of some major editing? any input would be greatly appreciated.
    Apr 2003
    3578
    you need the X+ setup sheet. what exact version of X2 are you using?
    Cadcam
    Dec 2007
    617
    Hi: You may need to edit the post in order for the software to calculate more accurate times using your rapid feedrate and chip to chip toolchange time.
    regards
    Can't Fix Stupid
    Apr 2003
    3578
    Sorry Cam1 not the Post but the machine def and control def as this contains the info on example time for a tool change and so on.
    Cadcam
    Nov 2005
    174
    I second the use of X+, it is one of the best setup sheets for MCX2. Do a search on emastercam, there is also alot of info to help set it up the way you want it to output.
    Jun 2007
    10
    Im using X2 MR2, and happened across X+ last night from an old colleague. let the adventure begin. thanks!
  1. MASTERCAM X2 BASIC SETUP SHEET
    By mt15racing in forum Mastercam
    Last Post: 02-22-2008, 04:26 PM
  2. Setup sheet in Gibbs cam
    By binzer in forum GibbsCAM
    Last Post: 08-23-2007, 02:52 PM
  3. Setup Sheet Problem
    By StormWerkz in forum Mastercam
    Last Post: 03-21-2007, 04:24 PM
  4. Mastercam Setup Sheet Help
    By stampman in forum Mastercam
    Last Post: 02-27-2005, 02:54 AM
  5. How to change the setup sheet format?
    By cwww in forum Uncategorised CAM Discussion
    Last Post: 06-30-2004, 08:28 PM
