603,370 active members*
3,452 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Joes CNC Model 2006 > Has anybody used "Boatboard" (marine HDPE) before?
    Apr 2006
    87
    I was researching and pricing out plastics when I came across a product called Boatboard a.k.a. Starboard (a modified HDPE for marine use) that looks really promising. A 13" x 13" x 0.5" sheet costs only $10 and it's available in 5 different colors. Even a one inch block of that size costs a mere $17. One downside is that it "has a slightly textured no slip, anti-marking surface". Provided that the texture is just a surface finish (ie: not formed by deliberately introducing microscopic bubbles while forming the HDPE sheet), it shouldn't pose too big of an issue for us.
    Here is where I found it: http://www.polyzone.com/asp/Product.asp?PG=2189
    Has anybody used this stuff before? Is it just as wear resistant and slippery as regular HDPE? Is there an even cheaper source for HDPE out there?
    Jul 2005
    12177
    Did you Google Boatboard?
    I thinkl it is just a marketing ploy aimed at boat owners. They call it a modified HDPE and I think the modification is the textured surface. The properties claimed are just standard for HDPE: doesn't rot, yes correct, doesn't delaminate, yes correct etc.
    And $10 for 13" by 13" at 0.5" thick is about $9.50 a square foot; is that much different to standard HDPE?
    Aug 2004
    3215
    same stuff as i buy.
    joe
    Apr 2006
    87
    From the same site, a 12" x 12" x 0.5" sheet of HDPE (natural) costs $37.50.
    Joe uses it, so that's pretty much a slam-dunk endorsement in my books.
    I found a Canadian site that carries the same stuff under the tradename of Starboard: http://www.theplasticstore.com/default.asp
    Sep 2003
    1113
    Yes - I used it for the "cars" on my System2. (see User's Photogalery)
    Starboard -- Cuts well - machines easy - you'll need to work stepover to get the finish right. Doesn't adsorb moisture - I've found it stable in "shop" conditions.
    Can't say if its "just" repackaged to target boaties -- but the price you found is probably 1/2 to 1/3 what you'd pay a marine supplier! There is a special 3M (I recall) adhesive. It will Drill and Tap - but if using as a drive for threaded rod -- you'll have some backlash!
    :cheers: Jim
    Experience is the BEST Teacher. Is that why it usually arrives in a shower of sparks, flash of light, loud bang, a cloud of smoke, AND -- a BILL to pay? You usually get it -- just after you need it.
  1. "low end" HF Spindle or "high end" router for about $1000?
    By biomed_eng in forum DIY CNC Router Table Machines
    Last Post: 01-06-2012, 07:15 AM
  2. BattleAxe "aka" Ball and Chain "aka" the wife.
    By ZipSnipe in forum Community Club House
    Last Post: 05-18-2008, 03:53 PM
  3. G320 "common" or "+5vdc" why do they vary?
    By beezerlm in forum Gecko Drives
    Last Post: 01-12-2008, 11:00 PM
  4. Vertical system "jerks" and "bangs"??
    By REVCAM_Bob in forum Servo Motors / Drives
    Last Post: 06-12-2006, 03:09 PM
