586,116 active members*
3,392 visitors online*
    May 2007
    155
    Haas probing Questions
    When you Probe a vise corner in VQC probing
    ands its finshed and moves the probe to the corner ..
    Go into offets and look @ G54 why do the numbers change on x and y
    if you press part Zero set .. shouldnt they stay the same ?
    Thanks for the help ...
    Jun 2006
    29
    It moves to a safe position near the corner....not to the corner. If it were actually at the corner, your 6mm ruby ball would be touching the vice by 3mm. The reason it changes when you hit part zero set is because you have just designated that safe position as G54 rather than the actual vice corner.
    I bet that makes sense, huh? Good luck.
    Jul 2005
    340
    it moves to the position where you started , just zero your operator positions and run the cycle it should be the same , have checked this in probbing a bore.
  1. 5 Axis Haas questions
    By PBMW in forum Haas Mills
    Last Post: 03-04-2013, 10:42 PM
  2. 93 Haas VF2 Homing Questions
    By Rcky123 in forum Haas Mills
    Last Post: 10-23-2007, 02:14 PM
  3. Probing and g10 questions matrix control
    By Liontastic in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 10-04-2007, 09:01 PM
  4. Haas Probing
    By binzer in forum Haas Mills
    Last Post: 09-26-2007, 03:52 PM
  5. Haas Lathe Questions - Lots
    By 1ctoolfool in forum Haas Mills
    Last Post: 08-14-2006, 12:47 AM
