588,685 active members*
5,975 visitors online*
IndustryArena Forum > CNC Electronics > Servo Motors / Drives > Help with Baldor Servo Motor and Drive
    Sep 2005
    92
    Hello, I have 2 Baldor BSM-90N-375AA Servo Motors and 2 Baldor BSC1115 servo Drives. My question is if this 2 can work together. My concern is that the motor is 19A Cont. stall current and the drives are 15A ARMS.
    The Servo Motor specs. are :
    General Parameters
    Cont. Stall Torque Lb-In (N-m): 117.00 (13.30)
    Cont. Stall Current: 19
    Peak Torque Lb-In (N-m): 470.82 (53.2)
    Peak Current: 68.4
    Electrical Parameters
    Torque Constant Lb-In/Amp (N-m/Amp): 6.88 (0.78)
    Voltage Constant Vpk/KRPM (VRMS/KRPM): 66.4 (46.95)
    Resistance: 0.21
    Inductance (mHy): 0.6
    Mechanical Parameters
    Inertia Lb-In-s2 (Kg-cm2): 0.0082 (9.2578)
    Speed at 300 Bus Volts (RPM): 4000
    Max Speed (RPM): 7000
    No. of Motor Poles: 08
    Feedback Device
    Resolver
    Speed: 1 SPEED
    And the specs. for the drive:
    BSC Servo Control Specifications: 230VAC
    Input voltage 230V–3φ
    Nominal Bus Volts 300 (280–350)
    Continuous Bus Current ARMS 15
    Peak Bus Current (1.5s ±.5s) ARMS 30
    Recommended Fuse Size  A 30
    Continuous Output Power Rating kVA 6.5
    Simulated Encoder Output ppr 250/500/1000/1024
    Efficiency % >95
    Nominal Switching Frequency kHz 8.5
    Minimum Load Inductance μH 200
    Analog Command Input VDC ±10
    Speed Command Potentiometer 5kΩ or 10kΩ, 0.5watt
    Balance (Offset Drift) RPM Adjustable to 0
    Thank you.
    Jorge
    Mar 2008
    114
    the best choice to drive bsm series motors is either flex drive or microflex - look up servo systems - they are a good baldor dealer who can get either of those products - they can also have a baldor tech answer questions about your current equipment.
  1. Baldor Vector Drive Problems
    By ferroma in forum Fadal
    Last Post: 09-04-2018, 06:50 AM
  2. Sell Servo Motor, Servo Drive by GSKcnc.com from China
    By salecnc@hotmail in forum News Announcements
    Last Post: 06-03-2008, 08:55 PM
  3. New Spindle drive (baldor)
    By Lonewolf32 in forum Fadal
    Last Post: 07-13-2007, 06:32 PM
  4. Baldor Servos And Drive
    By Cycle Start in forum Servo Motors / Drives
    Last Post: 05-29-2007, 01:28 PM
  5. Baldor Vector Drive Problems
    By MetalTech in forum Fadal
    Last Post: 12-10-2005, 03:38 PM
