586,657 active members*
3,498 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Mini Lathe > How to remove Spindle for high-low gear replacement?
    Jul 2008
    Due to a jam I lost my low gear on my mini lathe - both high-low gear-wheels need to be replaced (item numbers 14 and 24 here: http://www.littlemachineshop.com/Inf...33684Parts.jpg)
    I disassembled the head stock casting - but I don't know how to remove the spindle out of the bearings. Can anyone please advice how to do this?
    Thanks!
    May 2003
    325
    Look on Little Machine Shop for mini-lathe kits. They have a metal gear kit that has instructions for removal-replacement of the hi/lo gears. You don't have to buy the kit to get the instructions.
    robotic regards,
    Tom
    Nov 2007
    4
    Hi avh, Go here http://www.arceurotrade.co.uk/projects.aspx. Third article down I believe has step by step guide on replacing bearings and gears. You may have to cut & paste. Hope this helps.
    Jul 2008
    Tom & Mike - Thanks a lot, VERY useful information (good to know there are metal gears!), this helped me disassemble the headstock. Great pictures!
    I can also share one more piece of advice I received from Frank Hoose on his site: http://www.mini-lathe.com/Mini_lathe.../Headstock.htm
    Thanks to all!
  1. VF3 spindle high gear fault alarm #117 help!
    By JHR1 in forum Haas Mills
    Last Post: 01-01-2010, 05:39 PM
  2. VF3 Gear box replacement ????
    By msteckhan in forum Haas Mills
    Last Post: 12-15-2007, 03:33 PM
  3. Wells-Index Z-Axis Replacement Gear
    By askjerry in forum Uncategorised MetalWorking Machines
    Last Post: 08-06-2007, 05:19 PM
  4. How do I remove a kwik chuck/spindle
    By Andyh in forum Bridgeport / Hardinge Mills
    Last Post: 08-14-2005, 06:28 PM
