603,890 active members*
3,387 visitors online*
    Nov 2006
    22
    Wells-Index Z-Axis Replacement Gear
    I was machining a part tonight when my Z-Axis froze up. After getting the machine broken down into a pile of parts... I found the problem to be a nylon gear in the Z-Axis gearbox.
    I have a 1978 vintage Wells-Index Model 850 (I think) and I need to find a replacement gear. The gear is 1/2 inch thick, 56 teeth, and 3.64 inches in diameter. Any ideas who would have a replacement part?
    Also... does anyone have a manual that they could scan the parts list for me? I'd really find that helpful!
    Thanks,
    Jerry
    Mar 2007
    207
    Call Wells-Index!
    They are still in business and do a fantastic job supporting their old machines. I have been able to get any part I've ever needed.
    231-759-0950 ask for Rick Robinson.
    John
    Nov 2006
    22
    Smile Thanks!
    Thanks,
    I contacted them via email about the same time I made this post... I figured I would check options to be sure I'd get an answer. New gear is $81.00 which is about what I expected.
    I have a 35W laser engraver/cutter and I have some 1/4 inch sheets of delrin... I'm tempted to use gerar.lsp in AutoCAD to create a pattern and cut one from multiple sheets.
    I need to get a gear puller and yank this one to see if the center is round, keyed, or whatever. If it has some sort of key... I may try the laser method... I could have it done in a couple of hours for free. (Hey... I'm cheap.)
    Naw... I have a job to finish up... I'll just do it right.
    Hey... while I'm thinking about it... does anyone have a PDF of the manual? It would have been great to see how that stuff went together before I tore it apart... I was afraid of breaking something... I figured it all out... but it would have gone MUCH faster with the manual!
    Thanks again,
    Jerry
    http://www/rutherford-robotics.com
  1. Wells Index Mill mystery knob...What's it for?
    By Chris64 in forum Uncategorised MetalWorking Machines
    Last Post: 10-01-2008, 05:56 PM
  2. Repairing or retrofitting a Wells Index
    By Aley in forum Uncategorised MetalWorking Machines
    Last Post: 09-04-2007, 10:03 AM
  3. Wells Index model 747
    By wall!@# in forum Knee Vertical Mills
    Last Post: 04-27-2007, 08:17 PM
  4. Phototransistor + Index Pulse = Z Axis THC?
    By sunmix in forum Mach Software (ArtSoft software)
    Last Post: 10-26-2006, 03:30 PM
  5. Wells Index cnc iron ....FREE...but
    By gus in forum Bridgeport / Hardinge Mills
    Last Post: 11-16-2005, 07:13 PM
