586,195 active members*
4,110 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > 401 servo alarm (VRDY OFF), at turn on, Fanuc OM SOLVED
Page 1 of 2 12
Results 1 to 20 of 30
    Mar 2006
    107
    Eveything was OK with machine, until we have moved it from place to place, just for one meter, by hand, carefully, and cleaned (washer) it, also carefully.
    Now when I turn it on (main pow, nc control) and i pull out emergency stop, this alarm appears
    401 SERVO ALARM: (VRDY OFF)
    And I can't get rid of it, I push reset, it appears again, pull in/out EM STOP, alarm appears again.
    Machine is not movable (nor in handle mode).
    I have tryed to turn it off and on for several times, but no progress.
    And on servo amplifiers there is no alarm code, just " - " as not ready.
    I have red lot about this alarm, but it could be anything (wires, relays, amplifier, servo brushes, dirty servo.....?)
    And read again my first sentance, it may be important for finding solution.
    Sorry for bad english
    Sep 2005
    767
    You may have a limit switch that has stuck open or become shorted by the washing process. Look for limit switches on each axis (in both + and - direction). There are frequently TWO limit switches in each direction. One limit switch simply causes an Overtravel (OT) alarm, and you can then jog in the oposite direction to move off the switch. The second switch is an "Extreme" overtravel switch, and it is designed to protect the ballscrews and stop the servo positively if the first switch should fail, or if the CNC should ignore the OT switch. On some machines, that switch is tied to the 24v E-stop circuit, which will simply make the machine come up "NOT READY". Other machines, however, use the 100vac circuit to enable the servo contactors for that same purpose. If your machine is wired like this, and one of these switches was stuck on, filled with water, or otherwise defective, you will get your 401 servo alarm. Also look for damaged cables from these switches to the CNC, and inspect any connectors you may find along these cables. These extreme overtravel switches are usually wired as "normally closed" and are in series, so actuating any one of them breaks the circuit and shuts down all the servos.
    Mar 2006
    107
    Thanks for help, machine was in "middle" position, far from limit switches.
    Actually I have just solved the problem
    Silly me, we have reconected main power input to tramsformer, and one wire (one phase) was not tightened well, and there were just two phases connected.
    (nuts)
    Thanx
    May 2008
    107
    Hi all.
    I have the same problem: The alarm " 401" appear on screen when power on, I checked all wires, and can not find the reason. Pls. help me to fix this problem.
    May 2008
    107
    Pls., Pls. help me.
    Aug 2008
    7
    you have to check the power supply for the axis card it has some pines where you can test 25v 10v -25v or something like that maybe you transformator is broken
    May 2008
    107
    Dear robertox
    Thanks for your reply, but I checked all the wires and voltage, all it are normally( the machine was work fine before). Is there some thing else?
    Did you know how to turn on F148.6, it will turn on Y51.2 then show up the procedure.
    Sep 2004
    209
    Remove the cap from each axis motors and remove any brush dust (be careful, it's probably toxic!) and inspect/clean the commutator. While you're at it, check the brush length/condition and replace as required.
    I was getting persistant 401 errors on my mill and cleaning out the X and Y motors got rid of them almost completely. I still get the occasional 401 error, but I can usually clear it with one off/on cycle and it's probably because I didn't clean out the Z motor (which is buried in the machine casting).
    May 2008
    107
    Dear Scirchen
    Thanks for your reply, I'll check it tonorow.
    May 2008
    107
    Dear skirchen
    I checked already, this is AC motor, do you mean I need to check at encoder? But it's have no too. Pls. help me. Do you have servo amplifier manual( it's code AB-1003-O86), if yes, pls. sent it to me( e-mail: [email protected])
    Thanks for your time
    Sep 2004
    209
    Namnp2007,
    I'm not 100% sure, but I think that AC motors don't have brushes, so my fix isn't going to work for you. There are lot's of things that it could be; do a google search for "fanuc 401" and you will get lots of results. That's where I got the idea to clean out the brushes .
    Fanuc is a good source for the manuals (http://www.fanuc.co.jp/en/contact/index.htm). Plus, their tech department is usually very good about debugging problems over the phone, even if you bought the machine used. I once had a tech on the phone for over an hour; I was checking things on the machine while he was feeding me instructions.
    Chris Kirchen
    May 2008
    107
    Ok, thanks.
    Nov 2006
    51
    Im geeting the same 401 alarms on my clausing lathe 21i-T control. alarm appears on X, Z, and B axis. Machine has AC motors as well and switches are proxy. othing appears to be stuck to them. Any thoughts or ideas on how i can get this alarm off im all ears
    May 2008
    107
    Dear hydrospin
    Maybe you need to check some out put relay, when power on, you can hear one "click" sound, that indicated the Amplifier start work, at this time, maybe some relay work too( you can find by LED), but in my case, one of them had bad connection, so machine become down and 401 alarm appear.
    Hope to help you.
    Jun 2006
    9
    Hello
    Dear all
    I hope that this file may useful
    Attached Files Attached Files
    May 2008
    107
    401 VRDY Alarm
    Quote Originally Posted by congchipham View Post
    Dear all
    Dear congchipham
    Thanks for your reply, it's more usefull for us
    Aug 2008
    7
    Hello gents,
    what parameter i have to change to increase and decrease the spindle RPM i have a Fanuc OT-C control
    Mar 2006
    Re: 401 servo alarm (VRDY OFF), at turn on, Fanuc OM SOLVED
    Hello
    I read carefully this topic.
    Don't find any solution for my "401 VRDY OFF "
    I have a 0m-C controller and this error appear after 5-10 min from power-on even if the axis is not move.
    All the voltage 110V and 220V are OK...The ESTOP circuit are ok...I work with machine only for reference, 5min in program and...401...Can you give some ideas for repair.
    Thanks!
    May 2008
    107
    Dear DannyB.
    Maybe your amplifier was mailfuntion, you have to change it for double check.
    30
    Would like to add another solution with error code 401 (fanuc 0M).
    Before this error make us to feel sick every day for more than year!!!
    On the drive are five relays. Three of them are powered on in parallel.
    110V Coil of one of them was burn out. We replaced relay with new one (we used different size relay, original is very rare)
    And now our Fanuc works as new!!!
    Thanks to everyone (and of course google :-))) who wrote their solution!!!
Page 1 of 2 12
  1. 404 Servo Alarm (VRDY ON)
    By jcowie in forum Fanuc
    Last Post: 01-26-2021, 08:52 AM
  2. VRDY OFF Alarm
    By NID in forum Fanuc
    Last Post: 04-02-2014, 07:49 PM
  3. Replies: 0
    Last Post: 01-28-2013, 12:55 AM
  4. Alarm 403: VRdy off , Fanuc OM
    By ThomasS in forum Fanuc
    Last Post: 07-27-2012, 01:39 PM
  5. 401 servo alarm (VRDY off)
    By sting007 in forum Fanuc
    Last Post: 07-01-2011, 08:45 AM
