586,112 active members*
2,986 visitors online*
    Jul 2008
    Exclamation Where is the "start from line"
    Hi.
    I've downloaded the latest emc2 version, 2.2, but I can't find the option "start from line" in the axis interface. Was it taken off? Is it a problem in my machine ini file?
    hank's in advance.
    Apr 2007
    56
    I've only had 2.2.2 or newer and I've not run across a command like that.
    It sure would be handy to have though.
    Bill K.
    May 2006
    2420
    If you have your gcode loaded, select the line you want to start from and then go to the machine menu (top left of screen) and select "set next line" from there, then you just hit the "play" button and off it goes.
    Cheers.
    Russell.
    Jul 2008
    Thank's epineh.
    Now its working.
    May 2006
    2420
    No problem, good to hear it is working
    Russell.
  1. "low end" HF Spindle or "high end" router for about $1000?
    By biomed_eng in forum DIY CNC Router Table Machines
    Last Post: 01-06-2012, 07:15 AM
  2. Lets Start 3-axis "khattak Mill"
    By Khalid in forum CNC Wood Router Project Log
    Last Post: 01-14-2011, 11:37 AM
  3. 4020 fadal cant get past "Cold Start"
    By chipsahoy in forum Fadal
    Last Post: 03-08-2006, 01:29 AM
  4. "Fancy" single line font
    By DAB_Design in forum G-Code Programing
    Last Post: 04-25-2005, 09:04 PM
  5. How to do 2 "IF" statements on the same line?
    By murphy625 in forum CamSoft Products
    Last Post: 04-02-2005, 02:28 AM
