Hey:
I thought I would chronical the retrofit of my SM1 CNC to a PC based controller. This is my first, so any help would be appreciated.
I know i am going to have a ton of questions for the forum, so I will apologize in advance.
I have attached a pic of what I’m starting with. It is a 1984 model. I bought it from the original owner with all of the manuals and even some tapes! Other than being a little dirty on the outside (the electronics are sparkling clean) it's in pretty good shape. It even has a couple of new servos. Not a bad deal at $750 huh?
It has the BX controller but that, along with all of the original electronics is going to be sold.
Here's a current rundown of the products I have researched to use:
Hitachi X200 VFD
Bob Cambell combo board OR a CNC4PC c23
Gecko 320 drives (they work with the combo board) The servos are 80v. This is at the upper limit for the drives. Are they going to burn up? If i use the C23 board, i might look at viper drives
Since the servos are tach, I am going to need some encoders. Any suggestions?
I am probobly going to go ahead and replace the limit switches as well. Any suggestions there?
Mach3
I still need a power supply 80v 20 amps. Any suggestions? Do I need a power supply for each servo?
That's where my plan is after a few days of looking/calling around. It is not set in stone, but i would like to start buying some stuff soon. Am I making any big mistakes here? Is all of this going to work together? Any other suggestions? Am I missing any major componentry?
I'll post again when I have some news.
Pat
