586,094 active members*
4,137 visitors online*
IndustryArena Forum > MetalWorking > Bending, Forging, Extrusion... > Aluminum Press Brake Tooling Dies Punches ???? Advantages, applications?
Results 1 to 6 of 6
    May 2007
    88
    I'm guessing non-marring, good for plastics and SS. Or anytime you don't want carbon steel impregnated. Any other marvelous uses?
    May 2007
    88
    Homemade Press Brake Tooling ...rules to LIVE by for home made punch and dies
    Went to a shop today, they had lots. With the price of steel the way it is and it getting harder and harder to find good deals. I'm contemplating making quite a collection. Since i'm not doing production work i can't justify the cost of the real stuff just because of wear. Is there anything to avoid making from scratch(welding) Today I saw just about every type of punch / die made from scratch. I'd never seen anybody make a die out of angleiron before.
    Aug 2007
    264
    I've been running press brakes for years. My best advice would be to use common sense.....it'll get you a long way. Homemade punch and dies will work for just about everything, except the long stuff. Welding things together perfectly square tends to get alot tougher after about 3-4 foot long.
    What kind of tooling are you looking for? If you have a plasma cutter the options are limitless. You can cut several profiles out of .5 plate and weld them together. Very quick way of building dies.....does get a little on the heavy side though.
    Mike
    Aug 2007
    264
    Another thing I forgot to mention. Keep in mind that there is only a certain amount of tonnage that you should subject a homemade die to. It's better to overkill on the construction/material/welding to be on the safe side.
    Mike
    Jan 2007
    525
    Hey folks - would appreciate some quick advice. I just realized that my 24" box & pan brake doesn't have sufficient clearance for a few bends I'll need to do (16 gauge sheetmetal) so I'd like to purchase an H-frame hydraulic press with V-dies. I see lots of vendors with the presses, but where the heck do I find dies? I'm just a hobbyist, so I don't imagine some of the companies I found via google (e.g. http://www.midwestpressbrake.com/) would deal with me. I was hoping to see these products in MSC, Enco, etc, but cannot find them. Can someone point me in the right direction? Thanks!
    Tormach PCNC 1100, SprutCAM, Alibre CAD
    Apr 2019
    6
    You should check out this article to learn the aluminum press brake toolings used on hydraulic press brake machine.
    https://www.machinemfg.com/press-brake-ultimate-guide/
  1. Ever seen shear tooling for a press brake? Can't be too hard
    By douglasco in forum Bending, Forging, Extrusion...
    Last Post: 07-27-2008, 07:56 PM
  2. Machines, Tooling, Service, Applications
    By silverfoxx03 in forum News Announcements
    Last Post: 06-02-2007, 02:09 PM
  3. NorthStar Press Brake For 20 Ton Shop Press anyone ever use one?
    By dsmdude in forum Bending, Forging, Extrusion...
    Last Post: 04-13-2007, 10:01 PM
  4. I need someone with a Press Brake
    By murphy625 in forum Employment Opportunity
    Last Post: 01-25-2006, 11:11 PM
