it's a daewoo 250 lathe with Meldas 500L controller. it has a tool setter and when we set the tool for boring (lower side of probe) we have to go into the tool offsets and add 3.175 to the offest once it's inputted from the tool setter. I was wanting to know if anyone knew or knows how to fix this as it would be easier to fix than try to keep running this way. the probe for the turning (the top ) works fine .. it's just the one for the boring (or lower probe) that we have an issue with. I know it's a simple adjustment in the parameters. I once ran a Daewoo with fanuc controller and had the steps to calibrate the tool setter.. this is a little bit different to me. any help would be appreciated
thanks
